andypugh wrote: You would need to connect that input pin to the HAL pin "halui.joint.0.home" but I do not know if stepconf knows how to do that.
uptown47 wrote: If it only 'homes' when that halui bit is on but there's no way to set that bit within StepConf it seems a bit redundant?
uptown47 wrote: AIf I set StepConf up so that the inputs are "Both Limit X + Home", "Both Limit Y + Home" etc then I get a "Joint on Limit Switch" error within LinuxCNC
