Forum Header
Home switches not "seen" by linuxCNC
9 years 6 months ago - 9 years 6 months ago #91828 by MAG45
Thanks for the help, ill give it a shot not, have a good day!
No luck on any of the tests on any port :(
Last edit: 9 years 6 months ago by MAG45.
9 years 6 months ago #91829 by bevins
Check in hal Configuration, you can see what is working and what is not once you get your parallel port figured out.
9 years 6 months ago #92143 by MAG45
Never was able to figure out the parallel port issue, Guess im just going to put it back together with no home switches for now and run it to see if everything else is working as intended.
Time to create page: 0.193 seconds
