Forum Header
Can't get stepper motors to move at all
8 years 9 months ago #105078 by mpayne
First, thanks for taking the time to read my post. I’ve really tried to solve this on my own but I’m getting nowhere
I’m moving my CNC setup from a (very old) PC running Windows XP, Mach3 and a MX3660 to a new PC with a fresh install of LinuxCNC 2.7. I’m using the same MX3660 and the new PC has a PCIe parallel port card. The card is a SD-PEX10005 which is a netMOS 9900 chip. The system works on my XP machine
My problem is I cannot get any of the stepper motors to move. My parallel port is working because my E-STOP works in linuxCNC. I can press the button and LinuxCNC goes into stop mode. When I release the button it exits stop mode.
When I jog in LinuxCNC the display shows the spindle moving the correct direction, but my CNC machine is motionless.
I’ve tried running the step config many times trying different things, using my Mach3 XML file and using new config. I tried adding my user to the LP group in case it is a permissions problem. Nothing is working. I’ve read through the posts here and tried just about anything I can find. I’m out of ideas to try. Can anyone suggest something I can do to figure out the problem?
Thanks for your help,
Mike
8 years 9 months ago #105079 by Clive S
It would help if you uploaded your |Hal and Ini files from the config folder. It might be that the drives are not enabled.
8 years 9 months ago #105081 by mpayne
Thanks for the reply. Here are the INI and HAL files. Thanks!
File Name: MX3660.hal
File Size:3.35 KB
File Name: MX3660.ini
File Size:1.89 KB
8 years 9 months ago - 8 years 9 months ago #105082 by PCW
You might try doubling the step lengths to 3000 ns (3 usec) = the "reset time"
1500 ns is too fast for the MX3660
The MX3660 specs say 2500 ns minimum step length
( and minimum means on the edge of not working... )
Edit:
Also the MX3660 manual says this:
"If step & direction signal voltage is lower than 5 VDC, you may need to increase step
width and direction setup time (> 5 uS) to move your motors, or avoid loss of step."
Pretty sure the NetMOS 9900 is s 3.3V chip so you may need a reset time of 5000 ns
Last edit: 8 years 9 months ago by PCW.
8 years 9 months ago #105086 by mpayne
I tried increasing the times and still no movement. Here is the new HAL file that was generated
File Name: MX3660_201...27-2.hal
File Size:3.35 KB
8 years 9 months ago #105087 by PCW
You might try disabling the chargepump logic on the MX3660 just in case theres an issue with it
Time to create page: 0.198 seconds
