Forum Header
Forward Step / Backward Step - Vexta Question
8 years 5 months ago #110499 by andypugh
These signals are set up for an external e-stop switch / loop.
net estop-ext <= parport.0.pin-13-in ... net estop-out <= iocontrol.0.user-enable-out net estop-ext => iocontrol.0.emc-enable-in
Many configs without an external e-stop use a short-circuit:
net estop-loop iocontrol.0.user-enable-out iocontrol.0.emc-enable-in
linuxcnc.org/docs/2.7/html/man/man1/iocontrol.1.html
There are a few ways to handle this. I think you can choose to connect user-enable-out to a parallel port pin then loop it back through an e-stop to emc-enable-in. But that probably isn't necessary in all situations (and there is also the option of using "real" safety relays when it really matters, or a software equivalent ( linuxcnc.org/docs/2.7/html/man/man9/estop_latch.9.html )
Anyway, as things stand with your HAL you probably need to bring pin 13 high to allow the machine out of e-stop.
8 years 5 months ago - 8 years 5 months ago #110503 by BrendaEM
@Andypugh, I feel bad because I am not used to needing help from other people this much. Thank you.
So, letting Stepconf set up the e-stop pin was not going to be enough....
This creates signal called "net estop-ext " which reads hardware parallel port 13, correct?
It does respond if I remove/add the jumper, as read with the Hal Meter, which only pulls it low like all the other inputs. I don't think I can pull any of the inputs high with the board I am using, but once again I can get a TRUE or FALSE state from the Hal Meter, by jumping/removing the wire bridge. Tomorrow, I will wire a normally closed switch in there.
I thought that the Linuxcnc wanted wants a FALSE state to proceed, meaning that a NC Estop switch hadn't been tripped.
Moving onward...
Does this create a signal called "estop-out" which pretty much gets its input from the GUI button in axis? (via LinuxCNC's subsystem)
If so, then that line not going to help me. I just want my hardware button to toggle the screen button. I want to shut off the estop event so I can enable the screen Power button, so I can turn my machine on.
The next problem I am having is: I don't know if LinuxCNC is going to watch a HAL pin, or if I have figure out how to create an event.
(I would state that this is one of the most complicated things I have ever ran across in computing, and this is coming from someone who set up an OpenFoam case. I also feel I see the power of LinuxCNC and the HAL implementation, and what's doubly frustrating for me is that I want to help by figuring out a way to make it easier, so idiots like me, wouldn't be asking questions like this, and I can't do it yet. Me, feeling better after my release, the reader hopefully forgiving me for it....)
Wouldn't this be enough on it's own? As it's connecting the "estop-ext" signal to Estop watcher.
To read the documentaiton also looks like this is involved somehow, but no one has brought it into play.
iocontrol.0.user−request−enable
I don't understand why I would want to create signal loopback with nothing in between to control it, start it, or stop it. This would seem to lock the system into a state, but I how could I chose which?
Would this above line (from above) still have some control the state of the loop?
Sigh. I am not very confident my machine will be running soon : (
Last edit: 8 years 5 months ago by BrendaEM.
8 years 5 months ago - 8 years 5 months ago #110507 by andypugh
BrendaEM wrote: I feel bad because I am not used to needing help from other people this much
CNC systems are complicated. One of the most complicated overall systems that there are.
I am not sure what options you chose. If you selected a parallel port pin to be e-stop then I think it did the right thing.
Yes, that is correct.
You can invert the sense of the P-Port pin (in stepconf or by editing the HAL) to get this behaviour.
[strike]setp parport.0.pin-13-invert 1[/strike] (Edit) Sorry, input pins use the in-not rather than being explicitly inverted.
net estop-ext parport.0.pin-13-in-not
Yes.
That is certainly possible. I have a machine where the on-screen button is entirely under hardware control. (which isn't actually what I intended :-). I think that involves the pin you mention later, iocontrol.0.user-request-enable.
Every HAL pin is polled every mS.
Well, that isn't entirely true, HAL pins are actually shared-memory locations and each HAL module reads its inputs and updates the outputs every time the thread it is in runs (and the modules run in the sequence of the "addf" commands in the HAL file)
Yes. I think that stepconf just creates the estop-out signal in case you want to use it in a different HAL file. As far as I can see it isn't used in your HAL?
It might be worth fiddling with the pins in a simulator to see what happens.
If you open an axis sim config, then open Machine -> show HAL configuration you can set up a "watch" in the "watch" tab of the various HAL pins, and you can change their values in the command line at the bottom of the other tab.
However I prefer to issue the commands from a terminal window, because then you can have tab-completion.
halcmd -kf
Will link your terminal in to the running HAL session, and then you can link and unlink pins "live" and change their values. For example
unlinkp iocontrol.0.emc-enable-in setp iocontrol.0.emc-enable-in 1 setp iocontrol.0.user-request-enable 0 setp iocontrol.0.user-request-enable 1
It seems to work for simulator systems with no hardware. Presumably it's due to the order of execution.
I think you are very close.
You could comment-out the current e-stop lines (for the moment) and put in the loop
for testing.
Then you should be able to release e-stop and turn on the machine.
Last edit: 8 years 5 months ago by andypugh.
The following user(s) said Thank You: BrendaEM
8 years 5 months ago - 8 years 5 months ago #110536 by BrendaEM
Thank you Andypugh, that got the F1/F2 working as advertised. : )
So far, I can enable the GUI and moves things around on the screen.
Though, the machine still doesn't move. I tried setting the step parameters, slowing them down to quite far at 50,000ns and 500,000ns just to be sure.
(I also set up the machine limits, which seem okay, though I still have to decide about homing points, but that seems like I will be able to do that.)
I checked the Halscope, and the xup and xdown signals pulses are being created by the system, but I am unsure if they are going out to the parallel port.
I've been heavily commenting the HALs that I've been uploading, so that they might help someone else.
Thanks you again.
8 years 5 months ago #110538 by andypugh
Do your drives have an "enable" input that needs to be set?
Are the motors free or locked?
8 years 5 months ago - 8 years 5 months ago #110541 by BrendaEM
Hi Andypugh,
The disabling is not wired in. I usually run these drivers this way, and they have a separate holding current, which can be set fairly low, so they don't get to warm from holding.
The motors are indeed holding.
I might have found an issue. I hooked up the old Rigol 1054z, and I did see pulses coming from the parallel card.
The voltages look okay, not great but okay (I cursored them backwards in the pic, so the voltage is calculated backwards as well.)
The pulse is pretty rounded, but I don't think that's the problem.
However the pulse looks pretty short, not what I asked for.
I am going to try to make the high portion higher, and check a few more pins.
setp stepgen.0.steplen 50000 # High Portion of Step
setp stepgen.0.stepspace 500000 # Low Portion of Step
setp stepgen.0.dirdelay 500000 # Space Between Direction Change
Time to create page: 0.111 seconds
