ubuntu10.04 Lcnc 2.7 rtai error
11 years 2 days ago #64523 by bkt
Replied by bkt on topic ubuntu10.04 Lcnc 2.7 rtai error
The J1900 have a wrong ram because not start at all.
Instead I try with H97M gigabyte and I3 3Ghz 4° gen.
All ok .... whit any type of trik on rtai and cpu, withous disable sometings from bios, whit 6 glgears whindows and 2 firefox youtube open after 2 hour obtain
servo thread 1ms 10580
base thread 25usec 11900
I think if I block 1 CPU for linuxcnc an disable any things from bios all system work perfectly .
No see at all rtai error message. ..... Ubuntu 10.04 linuxcnc 2.7
giorgio
11 years 2 days ago #64527 by PCW
Replied by PCW on topic ubuntu10.04 Lcnc 2.7 rtai error
IMHO
I would toss out Ubuntu 10.04 as its no longer maintained and use Wheezy
I would not bother with isolcpus at all as it will just slow the system down to gain a few usec better latency
With hardware stepgens and servo systems, any latency in the 0 to 50 usec range is absolutely fine,
there is really no point in getting better (and up to 500 usec can be OK with the right hardware setup)
11 years 1 day ago - 11 years 1 day ago #64542 by bkt
OK message receipt but isolcpu I think it's useful if you want to run other programs at the same time to LinuxCNC ... or maybe this is a mistaken belief ?
and disable any thngs not seccesary by bios is a good things or not? ....
If I start from minimal installation of ubuntu 12.04 it may be advisable use it instead of debian?
Giorgio
Last edit: 11 years 1 day ago by bkt.
Time to create page: 0.049 seconds
