In response to my original post referring to the marginal graphics performance of N3150 CPU!
I found the reason for the marginal performance which had nothing to do with the CPU.
I had mistakenly installed LINUXCNC - 2.7.4-114-g92b991a by adding:
"deb
buildbot.linuxcnc.org/
wheezy 2.7-rtpreempt"
to my apt-sources.list instead of
"deb
linuxcnc.org/
wheezy base 2.7-uspace"
to install the official release "LINUXCNC - 2.7.4"
Being a new user I had actually done this on another install of a J1900 Cpu about 6 months ago and everything worked out well but I did not realize I was installing unofficial releases from the buildbot (until now when I encountered the problem).
LINUXCNC - 2.7.4-114-g92b991a was causing Gmoccapy to freeze which led me to blame the N3150 which now runs great with LINUXCNC - 2.7.4 installed onto wheezy 7.11 / 64bit with Preempt-RT. I'll continue to pursue the Mint route to see what improvements are to be had with the 4.4.7 kernel.
Perhaps It's a bit too easy sometimes for a new Linux user to type sudo apt-get install linuxcnc-uspace and not actually realize they are getting the latest version from what is defined in their apt-sources.list
Coming from windows it may help some folks to manually download the .deb package and install it with sudo dpkg -i to gain a better understanding of exactly which release they're installing.
Thanks,
CMB
