- Thank you received: 486
Does it have a pci or a pcix slotemcPT wrote: If you want a stable PC (this year I used it on more than 6 machines):
Motherboard MSI H97M-E35 1
Intel Pentium G3460 3.5GHz 3MB SK1150 (BX80646G3460)
4Gb of RAM
This PC build is quite solid and fast, preforms quite well in linuxcnc.
I like to bolt a 12V-supplied Mini-ITX board to a base plate then plug in an 8GB DOM SSD module
Clive s wrote: I have this above but does the DOM require a driver as the linuxcnc iso does not see it a a drive ?
I have booted from my SSD and there is no sign of it in /dev So I will try and send it back.andypugh wrote: If the BIOS can't see it, then I would suspect a fault.
Assuming that you are managing to boot from USB or similar, is there any sign of it in /dev/ ?
