my own designed 7i92 board not work
5 years 3 weeks ago - 5 years 3 weeks ago #222367 by PCW
Can you ping the card? (ping 192.168.1.121)
Mesaflash must use the --device ethernet command
and the 192.168.1.121 address until you set the card
name and EEPROM IP address address in the
cards EEPROM
I am using the standard mesaflash (3.4.0)
Last edit: 5 years 3 weeks ago by PCW.
5 years 3 weeks ago #222369 by mahdi2001h
No, I can't ping card !
I think the solution is to program the IP address on the eeprom network chip!
Do you have an opinion on this ?! Possible or how?!
5 years 3 weeks ago - 5 years 3 weeks ago #222371 by PCW
No, the card should respond to pings regardless of what's in the EEPROM,
because the 192.168.1.121 address is in the FPGA configuration, not the EEPROM.
I suspect a hardware issue. If you set the IP address jumpers to the
bootp setting (Up/Down on a 7I92) does the card transmit once per second?
(this should be visible on the link lights)
Actually I should step back a bit, before you run mesaflash,
have you programmed the FPGA via JTAG? (this is necessary to bootstrap the card)
5 years 3 weeks ago #222372 by mahdi2001h
yes! it's transmitting
5 years 3 weeks ago #222373 by mahdi2001h
and I programmed FPGA , in boot the user led blinked
5 years 3 weeks ago #222380 by PCW
OK, when you ping the card, do the user LEDs count?
Time to create page: 0.363 seconds
