Remora - NVEM / EC300 / EC500
- cakeslob
- Thank you received: 275
23 Apr 2025 16:39 #326968
by cakeslob
Are all the drivers the same, or did you do your check all axis with the same driver?
The following user(s) said Thank You: jjdege
- jjdege
- Thank you received: 34
23 Apr 2025 17:23 #326970
by jjdege
the same driver for all axes.
I tried to unsolder the chip, without success
the board does not respond, for now I do not think I will buy another
thanks for the support
Replied by jjdege on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
hiAre all the drivers the same, or did you do your check all axis with the same driver?
- Thayloreing
23 Apr 2025 23:56 #326983
by Thayloreing
Replied by Thayloreing on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Good evening everyone, I'm having a problem, I don't know where I'm going wrong, I do the ST Linkv2 procedure and it does everything right, but it doesn't appear as a unit on the PC, when I go to connect it to the PC with pyocd it doesn't find the ST Link, I've already bought 3 different ST Links and all 3 do the same thing, I don't know if my pyocd installation is wrong or not, I've redone the installation several times, I don't know where the problem is.
- jjdege
24 Apr 2025 15:18 #326998
by jjdege
by correct procedure you mean the one described by @Scotta to convert a STlink V2 into a CMSIS-DAP probe.
Pyocd will not see it as STlink, but as CMSIS-DAP
hiI do the ST Linkv2 procedure and it does everything right,
pyocd list
- Murphy
- Thank you received: 5
24 Apr 2025 18:13 #327007
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I'm trying to upload the config on another EC500 but I'm getting this error. It's bookworm installed from the linuxcnc iso on a PC.
- cakeslob
24 Apr 2025 18:45 #327008
by cakeslob
murphy, is this a new linuxcnc and remora install?
- Murphy
24 Apr 2025 19:05 - 24 Apr 2025 19:23 #327009
by Murphy
Yes Cakeslob it's for my mill. Bought a cheap 24" touchscreen from Amazon and got carried away testing it lol Static IP address, is it 10.10.10.10 or 10.10.10.11 for the board ?
Last edit: 24 Apr 2025 19:23 by Murphy.
- cakeslob
24 Apr 2025 19:36 #327012
by cakeslob
Looks like the board is at .10 and the PC should be .11
The following user(s) said Thank You: Murphy
- Thayloreing
26 Apr 2025 21:57 #327104
by Thayloreing
I managed to do so far, but when I give the command
sudo pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
nothing happens, it doesn't compile for the nvem board, but if I give the command pyocd list the address appears
- Murphy
28 Apr 2025 10:32 #327206
by Murphy
@cakeslob , I had a look at your hal file again and copied your spindle stuff exactly just changed for my pins etc and it's still the same. So I think that rules out a hal file problem. I don't think it's the vfd because I can change the speed manually by pressing the + and - manually in the Axis GUI and it responses quick with no dips when changing speeds.
Time to create page: 0.241 seconds
