Debian 11 RTOS on Beckhoff CX2030
4 years 1 week ago #254762 by MRBaird
Hello,
I am trying to get LinuxCNC 2.9 running on Debian 11.  I downloaded an ISO from Grotius.  Its the second ISO of his that i have used the first being a 4.19 version with EtherCAT master installed.  My problem is that I need to load two modules to Linux but the instructions on github.beckhoff/ page are not working.
### Linux Kernel 5.8 and BBAPI
Since Linux Kernel 5.8 it is not possible to dynamically load a Kernel module which allocates executable memory.
Therefore the BBAPI doesn't work as a loadable Kernel module anymore.
If you want to use it with Kernel Version>=5.8 you need to compile your own kernel and statically compile the BBAPI into your kernel.
I don't know how to do this.  The other module is CCAT.  and same thing the instructions say
## How to build and install the kernel modules:
1. cd into ccat <src_dir>
2. make && make install
But it doesn't work.  any help would be great.  I am not a Linux guy but can follow instructions.
The following user(s) said Thank You: Hc_eD
4 years 1 week ago #254771 by tommylight
How can we help you with that?
Post the error, screenshot, whatever that can help us help you.
4 years 1 week ago #254786 by MRBaird
My hope was someone could point me in the direction of compiling a kernal.  or maybe i could us DKMS.  I dont know how to proceed.  I am not a linux expert. all i do know is that  "make" is not working it has errors
4 years 1 week ago - 4 years 1 week ago #254796 by CORBETT
Can you point me to the 2nd ISO you got from GROTIUS.  I have a few SSD's with his ISO on it and wanted to see if this is a different version than what I have.
If it is over a year old, then the I don't think his ISO's will work any more.  I was going to burn an ISO of some of my builds, but he did it totally different than what I planned and he setup a nice fully working system.  His used a script to build everything and his script should fail at the mercurial part.  Grotius put a lot of work into his ISO and sad that mercurial migrated.   But he may have re-worked the script and I could have missed it.
I always wanted one of those Beckhoff IPC's.  I just never pulled the trigger and picked up one.  How do you like the CX2030?
*EDIT*
Kernel modules can be a pain, I remember having problems years ago with getting to a certain point in the EtherCAT build and it would not load the modules.  I remember doing a lot of reading and a lot of work to get it figured out, but I don't remember ever having to do it with Buster 10 (I know you're doing 11).  I had one setup that it ended up being an incorrect proc for the motherboard and therefore the kernel modules would not load (I had built it from parts and just stuck a working cpu in that I had, so that was my fault).  But I had this issue more than once years ago.
Last edit: 4 years 1 week ago by CORBETT.
4 years 1 week ago #254803 by MRBaird
The CX2030 is great it was from an old piece of equipment at work. The ISO was from this post forum.linuxcnc.org/18-computer/42057-lin...md64-download#203902 I have manged to start fresh from Debian 5.10.0-rt-amd64. I have got CCAT (the internal FPGA card that runs the attached etherCAT modules) working. i needed to copy the system.map to usr/src/linuxheader and change the name to system.map for CCAT to install. BBAPI seems like i will have to build it into the kernal. the BBAPI does things like buttons on the front of the PC and the display. I can live with out that for now.
I did have everthing working on Buster but wanted to move to probe basic so i figured jump in with both feet. i still have another hard drive with a working 2.8 LinuxCNC
The following user(s) said Thank You: CORBETT, Hc_eD
4 years 1 week ago #254818 by tommylight
Not even nearly sure, but it looks like not the same architecture.
Are you sure or is there any possibility of downloading the wrong architecture?
Most probably should be AMD64, not x86.
Time to create page: 0.142 seconds
