PCIe to ParPort - chipset PCI 60806A works?
1 year 6 months ago #325624
by Cherna
Replied by Cherna on topic PCIe to ParPort - chipset PCI 60806A works?
That makes a ton of sense, thanks for the insight.
1 year 6 months ago #325625
by Cherna
Here's the full pastebin with the entire log:
pastebin.com/BxPigz2U
Otherwise here goes the chipsets related to this board specifically (as far as I could understand):
09:00.0 PCI bridge [0604]: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:1080] (rev 04) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 16
Bus: primary=09, secondary=0a, subordinate=0a, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [78] Power Management version 3
Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [80] Express (v1) PCI-Express to PCI/PCI-X Bridge, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ SlotPowerLimit 10.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ BrConfRtry-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr+ FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <2us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [c0] Subsystem: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge [1b21:0000]
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
0a:00.0 Serial controller [0700]: TXIC Device [4651:7073] (rev 10) (prog-if 02 [16550])
Subsystem: TXIC Device [4651:7073]
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: I/O ports at c010 [size=8]
Region 1: I/O ports at c000 [size=8]
Kernel driver in use: serial
1 year 6 months ago #325645
by unknown
Replied by unknown on topic PCIe to ParPort - chipset PCI 60806A works?
what does
report ?
Sorry should have added these to begin with.
I had a look at a driver package for the card, bit of research came up with the correct PCI ID, and there was a utility for setting up the card, but it appeared to be a very very binary. Look if it works it works, but it would be interesting to know why lspci doesn't show a parallel port.
As Todd mentioned support gets added as the kernel matures.
sudo dmesg | grep parport
sudo cat /proc/ioports
report ?
1 year 6 months ago - 1 year 6 months ago #325646
by Cherna
The first command came up empty, so effectively no parports to be found.
And the complete log for the second command:
[/code]
Effectively, I have no idea why it doesn't mention a parallel port anywhere.
Edit: Just to add, it works flawlessly, I have been using the machine to cut some plywood, and it works like with the previous computer, not a single issue.
0000-03af : PCI Bus 0000:00
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0061-0061 : PNP0800:00
0062-0062 : PNP0C09:00
0062-0062 : EC data
0064-0064 : keyboard
0066-0066 : PNP0C09:00
0066-0066 : EC cmd
0070-0071 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : PNP0C04:00
00f0-00ff : fpu
0290-029f : pnp 00:01
03b0-03df : PCI Bus 0000:00
03c0-03df : vga+
03e0-0cf7 : PCI Bus 0000:00
0400-0453 : pnp 00:04
0400-0403 : ACPI PM1a_EVT_BLK
0404-0405 : ACPI PM1a_CNT_BLK
0408-040b : ACPI PM_TMR
0420-042f : ACPI GPE0_BLK
0430-0433 : iTCO_wdt.0.auto
0450-0450 : ACPI PM2_CNT_BLK
0454-0457 : pnp 00:05
0458-047f : pnp 00:04
0460-047f : iTCO_wdt.0.auto
04d0-04d1 : pnp 00:03
0500-057f : pnp 00:04
0cf8-0cff : PCI conf1
0d00-ffff : PCI Bus 0000:00
1180-119f : pnp 00:04
b000-bfff : PCI Bus 0000:0b
b000-b00f : 0000:0b:00.0
b000-b00f : ahci
b010-b013 : 0000:0b:00.0
b010-b013 : ahci
b020-b027 : 0000:0b:00.0
b020-b027 : ahci
b030-b033 : 0000:0b:00.0
b030-b033 : ahci
b040-b047 : 0000:0b:00.0
b040-b047 : ahci
c000-cfff : PCI Bus 0000:09
c000-cfff : PCI Bus 0000:0a
c000-c007 : 0000:0a:00.0
c010-c017 : 0000:0a:00.0
c010-c017 : serial
d000-dfff : PCI Bus 0000:06
d000-d01f : 0000:06:00.0
d000-d01f : ahci
d020-d023 : 0000:06:00.0
d020-d023 : ahci
d030-d037 : 0000:06:00.0
d030-d037 : ahci
d040-d043 : 0000:06:00.0
d040-d043 : ahci
d050-d057 : 0000:06:00.0
d050-d057 : ahci
e000-efff : PCI Bus 0000:01
e000-e07f : 0000:01:00.0
f000-f01f : 0000:00:1f.3
f000-f01f : i801_smbus
f020-f03f : 0000:00:1f.2
f020-f03f : ahci
f040-f05f : 0000:00:19.0
f060-f063 : 0000:00:1f.2
f060-f063 : ahci
f070-f077 : 0000:00:1f.2
f070-f077 : ahci
f080-f083 : 0000:00:1f.2
f080-f083 : ahci
f090-f097 : 0000:00:1f.2
f090-f097 : ahci
Last edit: 1 year 6 months ago by Cherna.
1 year 6 months ago #325648
by unknown
If it works it works.
Take the win
Take the win
The following user(s) said Thank You: Cherna
Time to create page: 0.099 seconds
