Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.9
Machine configuration directory is '/home/cnc/linuxcnc/configs/Cnc_xyz'
Machine configuration file is 'Cnc_xyz.ini'
INIFILE=/home/cnc/linuxcnc/configs/Cnc_xyz/Cnc_xyz.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=qtvcp qtdragon
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./Cnc_xyz.hal
Running HAL shutdown script
hm2_7i90: loading HostMot2 Mesa 7i90 driver version 0.3
hm2_7i90: wrote control 0x04
hm2_7i90: read status 0xFE
hm2_7i90: selected address 0x00
hm2_7i90: read data 0xFF
hm2: no firmware specified in config modparam! the board had better have firmware configured already, or this won't work
hm2/hm2_7i90.0: Low Level init 0.15
hm2_7i90: selected address 0x8100
hm2_7i90: read data 0xFFFFFFFF
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2/hm2_7i90.0: invalid cookie, got 0xFFFFFFFF, expected 0x55AACAFE
hm2/hm2_7i90.0: FPGA failed to initialize, or unexpected firmware?
hm2_7i90.0: board at (ioaddr=0x0378, ioaddr_hi=0x0778, epp_wide ON) not found!
hm2_7i90: rtapi_app_main: Invalid argument (-22)
./Cnc_xyz.hal:9: waitpid failed /usr/bin/rtapi_app hm2_7i90
./Cnc_xyz.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Cnc_xyz.hal:9: insmod for hm2_7i90 failed, returned -1
1645
Stopping realtime threads
Unloading hal components
these are the files and the response
