Encoder question
1 month 3 weeks ago #349409
If the drive and motor are a set, do not try to tune them before making sure that is the issue, for this:
-disconnect the analog drive input from Mesa
-connect those two wires together
-power on the drive
-enable the drive
>>>does the motor turn slowly ?
-If yes = move on the drive is fine
-If no = first thing to check is Tacho wiring and brushes, then check motor brushes (if any).
>also check the commutator state for both, if there are signs of sparking on tacho = change tacho and check the drive output to tacho for whatever signal it should output. Rarely an issue, very rarely.
-Use compressed air to blow the brush holes and do not breathe near it
-And VERY important, return the brushes in the same hole you got them from, in the same direction and orientation.
Replied by tommylight on topic Encoder question
Does it run slowly or at full speed?...but it just runs as soon as i enable it.
-power on the drive
-enable the drive
1 month 3 weeks ago #349432
by Tinker
Replied by Tinker on topic Encoder question
So the DC servo is like new, but coupled to a second hand drive that i had to replace the mosfets on. I bench tested the drive and it works very nicely with my power supply to control the servo. When i disconnect the +-10V from the mesa card it holds position and is what im assuming is waiting on a +-10v signal. When i hook the +-10v back to the Mesa card it just starts running until i get a following error. It is unresponsive when i try to command a jog signal, it just runs and then errors out.
1 month 3 weeks ago - 1 month 3 weeks ago #349433
by Tinker
I did inspect the tack and servo and the brushes and both commutators look like they were never used. Also, my pid settings are now in a usable state, not perfect but better than the all zeros that were in place before. They didn't transfer over for some reason and i missed that one.
Last edit: 1 month 3 weeks ago by Tinker.
1 month 3 weeks ago #349439
Replied by PCW on topic Encoder question
Is it possible you have the feedback reversed?
(check by changing the sign of the PWM scale)
1 month 3 weeks ago #349443
Can you move it by hand? Does it kick back in place when released? Or does it actively refuse to move?
Analog servos should turn slowly when there is no input signal.When i disconnect the +-10V from the mesa card it holds position and is what im assuming is waiting on a +-10v signal.
1 month 3 weeks ago - 1 month 3 weeks ago #349445
by Tinker
So i tried changing the sign of the scale via Mesa CT with no change, also tried changing the analog scale so they were backwards with no change.. should i try changing something in my hal file or ini? I also tried swapping the +- leads going to the drive and that didn't work, i had to change some +- signs with the scale and encoder and basically gave me the same result but now in reverse...
Time to create page: 0.131 seconds
