tangential knife along multiple layer height
8 years 1 month ago - 8 years 1 month ago #118013 by andypugh
It would be really nice if LinuxCNC could output a current heading angle for this application, but it isn't a 100% solution even if it could.
For a welder I feel that this might be better handled by a G_code filter that inserts a C axis move between each straight line move, and adds one to each arc.
This would also allow the possibility of turning off wire and arc at corners if the change in angle is enough to take a long time.
Last edit: 8 years 1 month ago by andypugh.
8 years 1 month ago #118092 by 0jw
Yes, I can see how it would be hard for the A axis to remain synchronized with the xy. I'm not exactly sure what you mean by G-Code filter. I'm a bit familiar with people using spreadsheet to edit the g code but my trigonometry is not that good and I haven't found anything that will allow me to add a specific line beneath other designated G Codes automatically. I read on another forum of someone using a method called "postpost" that sounds similar to what you're describing. I'm honestly surprised that there isn't a tangential post processor that isn't just 2.5D
8 years 1 month ago #118108 by andypugh
See this section on the INI config docs:
linuxcnc.org/docs/2.7/html/config/ini-co...html#_filter_section
The sample Python file is quite close to what you need. It would need to calculate an C-heading from any X and Y changes in a G1, G2 or G3 move and insert that before the original G-code line, and also add a through-the-move C rotation appended to the move itself.
1 year 7 months ago #325015 by vre
Is there any other cam software for tangential knife except sheetcam ?
1 year 7 months ago #325115 by Grotius
Hi Vre,
This for info. I hope you can use it.
The linuxcnc scurve planner has now tangential knife output value to hal.
The hal rotational output value could be coupled to a axis motor or device for rotation.
Within the the planner you can also benefit from the clothoid fillets, where the path
tends to be g3 continu, ideal for a drag knife application.
The following user(s) said Thank You: vre
1 year 7 months ago - 1 year 7 months ago #325143 by vre
scurve planner is in master?
Have you completed it and is in working state?
Last edit: 1 year 7 months ago by vre.
Time to create page: 0.430 seconds
