- Thank you received: 4
Can you enable/disable radiobuttons and checkbuttons in pyVCP?
- tropostudio
- Topic Author
3 years 5 months ago #272385
by tropostudio
I am trying to emulate the hardware pushbuttons, LEDs, rotary switches, et. al on control panel of an existing machine in a pyVCP panel. Current testing as I work out the layout is by running a simple shell demo with a pyVCP.xml file and associated pyVCP.hal file A few questions I'm not quite sure about, even after reading the the LinuxCNC Documentation:
1) Is it possible to 'latch' (toggle) a regular button? I figured out how to disable a button with another input, but would like to be able to latch a regular button closed/true instead of just being momentary.
2) Is it possible to disable an entire radiobutton array? I've not succeeded in disabling an array or even a single radiobutton. FWIW, I am using radiobutton arrays to emulate existing multi-position selector switches.
3) Is it possible to disable checkbuttons? I am using them to emulate keyswitches and as toggle buttons (although I'd prefer to use 'latched' regular buttons in most cases (see question 1).
Thanks!
Thanks!
3 years 5 months ago #272394
Replied by cmorley on topic Can you enable/disable radiobuttons and checkbuttons in pyVCP?
Isn't there an optional disable HAL pin?
To be frank it sounds like you should be using one of the more sophisticated VCPs.
3 years 5 months ago #272396
Replied by rodw on topic Can you enable/disable radiobuttons and checkbuttons in pyVCP?
Yeh, build a panel for qtdargon. When you get stuck, Chris will sort it out with you. He did that for me and even stole my masterpiece as an example now in the core code and the docs.
The following user(s) said Thank You: joekline9
- tropostudio
- Topic Author
3 years 5 months ago - 3 years 5 months ago #272442
by tropostudio
Replied by tropostudio on topic Can you enable/disable radiobuttons and checkbuttons in pyVCP?
cmorley - I didn't find any properties associated with disabling radiobuttons and checkbuttons in the Configuration:Control Panels:pyVCP:Widgets section of LinuxCNC_Documentation.pdf. I Googled a bit more and didn't find anything specific. Guess I was curious if there were additional properties not listed in the LinuxCNC doc. I may delve into GladeVCP, but writing XML files in Geany for pyVCP is really simple for someone who is better with hardware than code.
The purpose for this initial VCP is just to sort out IO and setup for a a VMC conversion that will retain 95% of the original machine hardware and electronics. Pics of the revised control panel and machine cabinet are attached. A CTI USB keyboard and small USB/HDMI touchscreen replace the original monitor and keypad. Ultimately I envision a simple, tab-based interface onscreen that does not try to duplicate all the hardware interface. IO is taken care of through 2 MESA 6i24 PCIe cards. Seven Mitsubishi servos controlled via a Yurtaev PCI adapter card. IO runs through my custom opto boards (green pcb's on the machine cabinet wall).
rodw - I'll take a look at QtDragon. Thank you both.
Last edit: 3 years 5 months ago by tropostudio. Reason: pics were too large and typos
- tropostudio
- Topic Author
3 years 5 months ago #272452
by tropostudio
Found the QtDragon page at
linuxcnc.org/docs/devel/html/gui/qtdragon.html
. Also found the QtVCP page at
linuxcnc.org/docs/devel/html/gui/qtvcp.html#cha:qtvcp
. Great stuff. Strange that I had to find them through a Google search rather than through a link on the linuxCNC.org site
Very cool, and great documentation - I will look into it for developing a future UI. In the meantime, I think I can do everything I need to right now in pyVCP by becoming familiar with the HAL commands.
3 years 5 months ago #272461
Its all linked on the main page. You need to take care which version of the docs you open . You need to select V 2.9
Don't forget that QTVCP is also well documented
Time to create page: 0.302 seconds
