- Thank you received: 4
Can you enable/disable radiobuttons and checkbuttons in pyVCP?
- tropostudio
- Topic Author
3 years 5 months ago #272464
by tropostudio
Replied by tropostudio on topic Can you enable/disable radiobuttons and checkbuttons in pyVCP?
Much appreciated. Thank you.
3 years 5 months ago #272469
Replied by cmorley on topic Can you enable/disable radiobuttons and checkbuttons in pyVCP?
yes I see in pyvcp only labels, leds and push buttons have disable pins.
I guess I didn't need radio pins at the time
- tropostudio
- Topic Author
3 years 5 months ago #272475
by tropostudio
Hah! The radio buttons serve as a good interface substitute for several multi-position rotary switches on my panel. A couple of those rotary switches are modal (value assignments of each position dependent on whether in manual jog or auto mode, etc). This can all be worked around since it I see it more as a test interface, not a user interface. Get the machine to run first, then make it better!
