Compiling Altivar VFD Modbus comp
11 years 7 months ago #57204 by Swapper
Hi
i tried the sniffer you provided
socat -d -d PTY: PTY
halrun:
loadusr -W atv_vfd -g -r 19200 -s 1 -t 1 -v -d /dev/pts/5
setp atv_vfd.spindle-on 1
cat /dev/pts/6
No results at all from cat
if you can try the same on 2.8 it would be very appreciated!
11 years 7 months ago #57205 by andypugh
You _must_ set atv_vfd.enable to 1 otherwise nothing at all happens.
here is the source-code
594 // wait for enable signal after load axis 595 while (!*(haldata->enable)) { 596 // do nothing 597 sleep(1); // be nice to CPU -mah 598 }
11 years 7 months ago #57221 by Swapper
Hi
Oh now where getting some errors at least :)
halcmd: setp atv_vfd.enable 1
halcmd: read_data: reading setup parameters:
ERROR invalid crc received 208 - crc_calc 5846
main: read_data retval=-16
ERROR Communication time out
main: write_data retval=-16
main: read_data retval=-12
main: write_data retval=-12
11 years 7 months ago #57325 by Swapper
i gave in and hooked the VFD up with analog control, maybe someone will get it running in the future.
1 year 8 months ago - 1 year 8 months ago #321970 by nawaf
Controling  Altivar VFD ATV 310. I am using the driver provided by @dgarrett with slight modification.
$ source ~/linuxcnc-dev/scripts/rip-environment $ cd ~/atv_vfd $ make clean $ make$ make atv_vfd $ make install
and  its works
Don't forget to set the parameters in ATV 310
  • 401 : Reference Channel 1 = 164 (for modbus)
  • 406 : Channel Configuration = 02 (for separate mode)
  • 407 : Command Channel 1 = 10 (for modbus)
  • 701 : Modbus Address = 01
  • 302 : Rated Motor Power = Nominal motor power given on the nameplate, in kW
  • 304 : Rated Motor Voltage = Nominal motor voltage is given on the nameplate, in V.
  • 305 : Rated Motor Current = Nominal motor current is given on the nameplate, in A.
  • 306 : Rated Motor Frequency = Nominal motor frequency is given on the nameplate, in Hz.
  • 307 : Rated Motor Speed = Nominal motor speed is given on the nameplate, in RPM.
Last edit: 1 year 8 months ago by nawaf.
Time to create page: 0.059 seconds
