Getting Halcompile to work
10 years 1 month ago #80026 by andypugh
Replied by andypugh on topic Getting Halcompile to work
jwsigler wrote: If people like to use a Windows based system to create their HAL component files, I have found that WordPad can be used to create Hal Component files.
Notepad++ is probably a better bet, it does syntax highlighting and other nice things.
Ithe sooner they release the Linux version the better :-)
10 years 1 month ago #80028 by jtc
Replied by jtc on topic Getting Halcompile to work
I use it on Linux, emulated with wine.
For me is one of the first things to do when installs Linux :)
2 years 8 months ago #293578 by MFairleaf
I had this same error message but for different reasons. I don't think your problem was line endings. It is possible that when you retyped the file you fixed one or more syntax errors.
In my case I had forgotten to put the double semi-colon at the start of my custom component.
To get halcompile to work, try copying one of the examples into your text editor saving as example.comp and then try to halcompile --preprocess example.comp
That should at least prove that halcompile is working even if it doesn't make your error apparent.
2 years 8 months ago #293604 by andypugh
"need more than one value to unack" is caused by a failure at the pint that the input file is split into two sections at the ";;" marker.
There could probably be a specific test for this step going wrong, wrapping the split in a try/except
2 years 8 months ago #293605 by andypugh
Incidentally, 8 yeas ago I was a fan of Notepad++ but now I use Geany on Linux, Windows and Mac.
Time to create page: 0.119 seconds
