Axis Y two motors gantry with separate switch home-offset
7 years 3 months ago #140445 by Marco
exactly, what should i do to upgrate my linuxcnc ? i dont understand what i have to do..
7 years 3 months ago - 7 years 3 months ago #140521 by BigJohnT
rodw wrote: However, if its a plasma table, I'd go straight to V 2.9 to get the reverse run.
Why would you want reverse run for a plasma table?
JT
Last edit: 7 years 3 months ago by BigJohnT.
7 years 3 months ago #140522 by tommylight
It is very helpful to have it for cases where the arc is lost during a cut or due to plasma overheating, you can just back off a bit and resume cutting.
Without it the procedure would be to run from line after choosing a straigh line somewhere before the arc was lost.
When cuting straight lines that is no issue at all, but when cutting art there are usually a lot of arcs involved.
Not a deal breaker in any way, just nice to have.
The following user(s) said Thank You: BigJohnT, rodw
7 years 3 months ago #140523 by BigJohnT
Maxardi99 wrote: exactly, what should i do to upgrade my linuxcnc ? i don't understand what i have to do..
Assuming your using Debian 9 my instructions for installing different versions of LinuxCNC are here . You will need to open the Synaptic Package Manager from the System > Administration menu and in Settings > Repositories uncheck the current LinuxCNC repos first.
JT
7 years 3 months ago #140542 by BigJohnT
tommylight wrote: It is very helpful to have it for cases where the arc is lost during a cut or due to plasma overheating, you can just back off a bit and resume cutting.
That makes sense to me, I don't run full out production on my plasma table so I've never experienced a shut down due to over heating.
JT
Time to create page: 0.311 seconds
