link two different signals to the same output
2 years 8 months ago - 2 years 8 months ago #292423 by greg23_78
my macro works straight away, calling it manually with the mdi works,
I looked to see if the home-carousel signal changes to high when I press home-all. the signal doesn't receive the information, so the problem is really with halui.home-all.
should i create joint_3 and set up HOME_SEQUENCE = 3 or there is a simpler solution for the homing sequence because joint.0.homed instead of halui.home-all allows the carousel to work, but at the detriment of an axis that does not perform the homing sequence.
Last edit: 2 years 8 months ago by greg23_78.
2 years 8 months ago #292469 by spumco
Are you using an external button or a user-created screen button to trigger halui.home-all?
If you're just using a standard on-screen 'home-all' button or command then halui.home-all isn't getting triggered.  The GUI is likely using it's own python command to trigger the home-all function.
Try connecting your halui.mdi macro to motion.is-all-homed.  That should trigger the carousel to home after all joints are homed regardless of what initiates the home-all sequence.
2 years 8 months ago #292554 by greg23_78
thank you, it works perfectly. i have a question: isn't there a danger that MDI_command-01 will remain continuously high?
2 years 8 months ago #292575 by spumco
Yes.  If you look back in the thread I pasted a snip from one of my configs that has a 'one-shot' component in it.
Using a oneshot between the motion.all-is-homed and the halui MDI command is the way to keep the is-homed from forcing the MID command high all the time.  The same result can be had from classic ladder using a rising-edge coil.
Either way (HAL or ladder), you want a 'blip' to trigger the MDI command - like a momentary button instead of a on/off switch.
If you need help setting up the oneshot after reading the LCNC manual (in the components section), just ask.
2 years 8 months ago #292678 by greg23_78
everything is working correctly, thank you spumco for your help.
for anyone interested in the carousel home in the home-all sequence.
Ini:
[RS274NGC] REMAP= M901  modalgroup=10  ngc=home_carousel [HALUI] MDI_COMMAND = M901
home_carousel.ngc
o<home_carousel> sub ; Move carousel section M68 E0 Q1 ;set the carousel to move to the right pocket     M64 P0  ;Enable Carousel     G4 P2  ; Wait 2 seconds     M66 P0 L3 Q120 ; wait for carousel-ready = true         o203 if [#5399 LT 0]         (abort, carousel not finished)         o203 endif          M65 P0  ;Disable carousel enable      o<home_carousel> endsub [1]
hal
loadrt oneshot count=1 addf oneshot.0                servo-thread setp oneshot.0.width 1 net home-carousel-oneshot-in         oneshot.0.in <= motion.is-all-homed net home-carousel-oneshot-out       oneshot.0.out => halui.mdi-command-01
I'll see later if I need to reset the pulse
Time to create page: 0.312 seconds
