Vista CNC and 2.9
2 years 5 months ago #301915 by spumco
Replied by spumco on topic Vista CNC and 2.9
So... as you mentioned in the first post, signal 'spindle-on' is connected to your parport pin, which is what turns the spindle on.
I don't know what's connected to that signal - i.e. what input drives that signal.  Perhaps something in your GUI?  What GUI are you using?
Can you look in halshow and see what pin is connected to signal 'spindle-on'?
Reason I'm asking is because I think you need an or2 component so that either the vista output or the GUI output can start/stop the spindle.  And we need to know what pin is currently driving the signal so we can set up the appropriate or2 logic.
2 years 5 months ago #301917 by milu
Replied by milu on topic Vista CNC and 2.9
According to halshow, nothing is connected to spindle-on (although, as you mention spindle-on is connected to parport). I tried something like:
net spindle.start vc-p4s.spindle.start => spindle-on
But it causes linuxcnc to abort on launch because it can't find spindle-on and I don't know any other way to refer to spindle-on.
For what it is worth, even the current setup seems to cause a command to start the spindle to be written to shared memory, and then read back, but nothing happens.
2 years 5 months ago - 2 years 5 months ago #301931 by Aciera
Replied by Aciera on topic Vista CNC and 2.9
I think you are confusing 'signals' and 'pins'.
With this line you assign the pin 'parport.0.pin-01-out' to a signal named 'spindle-on'
net spindle-on => parport.0.pin-01-out
to connect that signal to another pin you would use:
net spindle-on <= vc-p4s.spindle.start
Note that the '<=' and '=>' are optional and only help the user to see the direction of the information.
[edit]
for more information see section 1.4:
www.linuxcnc.org/docs/html/hal/basic-hal.html
Last edit: 2 years 5 months ago by Aciera.
2 years 5 months ago #301983 by milu
So I changed it to match what I think is your suggestion:
# 12---SPINDLE
net spindle.is-on halui.spindle.0.is-on => vc-p4s.spindle.is-on
#net spindle.start vc-p4s.spindle.start => halui.spindle.0.start
net spindle.stop vc-p4s.spindle.stop => halui.spindle.0.stop
I assumed this would allow the pendant to turn the spindle on (but maybe not off), but it does neither. Did I get this wrong?
2 years 5 months ago - 2 years 5 months ago #301984 by Aciera
Apologies, I was trying to show how signals are different from pins.
Try this:
# 12---SPINDLE
net spindle-start <= vc-p4s.spindle.start => halui.spindle.0.start
net spindle-stop <= vc-p4s.spindle.stop => halui.spindle.0.stop
net spindle-is-on <= halui.spindle.0.is-on => vc-p4s.spindle.is-on => parport.0.pin-01-out
Last edit: 2 years 5 months ago by Aciera. Reason: Change signal names to make them look less like pins
2 years 5 months ago #302010 by milu
I replaced my section 12 with the code you suggest and linuxcnc aborts with:
./vc-p4s.hal:109: Pin 'parport.0.pin-01-out' was already linked to signal 'spindle-on'
So I commented this line out in the main hal:
#net spindle-on => parport.0.pin-01-out
and that fixes the error, but the spindle still does not operate.
Can I ask a basic question? If this section of src/emc/motion/command.c is reached (which it is) shouldn't the spindle turn on?
case EMCMOT_SPINDLE_ON:
rtapi_print_msg(RTAPI_MSG_DBG, "SPINDLE_ON: spindle %d/%d speed %d\n",
emcmotCommand->spindle, emcmotConfig->numSpindles, (int) emcmotCommand->vel);
spindle_num = emcmotCommand->spindle;
if (spindle_num >= emcmotConfig->numSpindles){
reportError(_("Attempt to start non-existent spindle"));
emcmotStatus->commandStatus = EMCMOT_COMMAND_INVALID_COMMAND;
break;
Time to create page: 0.060 seconds
