Fadal Retrofit - ATC cycle
8 years 1 week ago #119291 by BigJohnT
Replied by BigJohnT on topic Fadal Retrofit - ATC cycle
COlger81 wrote: For some strange reason, some basic python commands were not executing, for example; "sys.exit()"
Python does not randomly not execute code. If some bit of code is not executed then it is not being called.
JT
8 years 1 week ago #119296 by BigJohnT
COlger81 wrote: I'm going through a retrofit of an AC Fadal 3016L. I have the mill running perfect with manual tool changes. I just started writing code for the non servo ATC in python. Is python the right method for the ATC or should i go with a different method?
You would get better exposure if you started your own thread in a more appropriate section like Advance Configuration. Most folks that come in this section are looking for Classicladder help or to answer Classicladder questions not Python.
JT
8 years 3 days ago #119601 by COlger81
Replied by COlger81 on topic Fadal Retrofit - ATC cycle
Nitram, could you send your files pertinent to the tool changer?
1 year 6 months ago #326032 by Miller Turner
Hi Chris,
Are you willing to share your Fadal LinuxCNC retrofit experience?
It will be much appreciated as others including myself are looking for details on how such retrofit can be done.
Time to create page: 0.351 seconds
