[Solved] Classic Lader doesn't run E-stop
  • aleksamc
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 9 months ago - 5 years 8 months ago #197390 by aleksamc
In the postgui.hal I connected such pin:
net estop-ext classicladder.0.out-00 => iocontrol.0.emc-enable-in
But when out-00 is TRUE, machine is disabled.
Why I don't understand. I'm only move pin from hardware input to classiclader output.
File Name: custom_2021-02-02.hal
File Size:2.14 KB
File Name: my_cnc_2021-02-02.hal
File Size:11.1 KB
File Name: postgui.hal
File Size:1.07 KB
Last edit: 5 years 8 months ago by aleksamc.
  • aleksamc
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 8 months ago #197526 by aleksamc
Replied by aleksamc on topic Classic Lader doesn't run E-stop
Nevertheless of emc-enable-in is true,
iocontrol.0.user-enable-out is FALSE.
What make iocontrol be deactivated?
  • aleksamc
  • Topic Author
  • Platinum Member
  • Platinum Member
5 years 8 months ago - 5 years 8 months ago #197536 by aleksamc
problem was solved. Answer is here
The following user(s) said Thank You: Soccer Kid
Time to create page: 0.049 seconds
