uli12us wrote: Is it right, that the 7i77 have no LEDs for the digital in and outputs. If yes I must make a small Input and outputcard to see, which of the connectors is switched. I think I can see it on the Screen, but if I work behind the machine I must see which sensor is switched, and which actor (most solenoid valves) is activated.
sneci wrote: I installed an Precise (32-bit) system and rt-preemt kernel based on Andy description.
It works well, but I can not find the 7i80 bit file. Where can I download it?
