Spinx1 to 7i85
10 years 11 months ago #66132 by andypugh
Replied by andypugh on topic Spinx1 to 7i85
OT-CNC wrote: Looks like its working! Need to tune now unless I'm still missing something. There are oscillations on the slow rpm, I see the cw/ccw leds on the spinx pulse at super low rpm. I also get pulsation at max rpm.!
That does sound like tuning.
I am not sure what the Machine->Calibration utility uses to find things to tune with.
You can achieve nearly the same convenience from the halcmd prompt.
Open a terminal, then haldmd -kf
The setp pid.0.PGain 100 (etc)
When it seems to be working, "show pin pid*" then copy those values to the INI file.
halcmd has tab-completion and history, so up-arrow will take you back through previous commands.
The following user(s) said Thank You: OT-CNC
10 years 11 months ago #66193 by OT-CNC
Replied by OT-CNC on topic Spinx1 to 7i85
halcmd -kf worked. Thanks for the advice. Besides tuning, I ran into another issues of the rpm being off.
I noticed that the Hz displayed on the vfd do not match the rpm. If I type s60, I get 10hz, at s1 I get .5hz, S880 is 118hz! As set up, (118)120hz is max in the vfd and the motor spins full rpm around 3495rpm. In other words, linuxcnc is giving me full rpm starting around s700 on and up.
My simple configs have the rpm correct. What do I change in my vel mode?
Another question is in regarding tuning, if I check in hal configuration and look at the signals spindle-vel-cmd and spindle-vel-pid, should the values be close? My pid value come in much greater.
The encoder setup should be okay .When I rotate the spindle in pos mode, 0 and 180 are in the correct spot.
10 years 11 months ago #66205 by andypugh
OT-CNC wrote: halcmd -kf worked. Thanks for the advice. Besides tuning, I ran into another issues of the rpm being off.
Ah, yes. As we switched the command and the feedback and the PID to revs-per-sec, you need to change the PWM scale to give 100% duty cycle at 60 revs-per-sec not 3500 rpm. Just change the pwmgen,0,scale to 60.
10 years 10 months ago #66220 by OT-CNC
Andy, I have setp hm2_5i25.0.pwmgen.00.scale 60 already set and it's off. Does the pwm frequency need to be changed as well? It's set at 5khz (5000).
10 years 10 months ago #66221 by andypugh
OT-CNC wrote: Andy, I have setp hm2_5i25.0.pwmgen.00.scale 60 already set and it's off. Does the pwm frequency need to be changed as well? It's set at 5khz (5000).
No, that should be fine.
First things first, have you tried with P I and D set to zero, and then adjusted FF0 to give a good speed match at mid-speed?
10 years 10 months ago #66222 by OT-CNC
Okay, just adjusted the FF0 to give me 60 hz at s1765. That works!! Doing the PID in the terminal is awesome.
What is next? FF1, FF2?
Moderators: PCW, jmelson
Time to create page: 0.296 seconds
