I was confused for a while by the presence of a step pin for channel 3. But that is set up for a charge-pump.sakumar wrote: Looks like the MX3660 bitfile supports upto 3 steppers, but the MX4660 supports up to 4. So although the pins match for the first three steppers,
there is no support for the fourth.
Is this something I can fix via configuration or do I need to get a new bit file from Mesa?
PCW wrote: freeby.mesanet.com/7i92step.zip
is a basic example hal/ini file set for the 7I92
You cal also run pncconf for a 5i25/probrfx2 setup and edit the resulting files
(changing the card name to 7i92 and the hostmot2 config line to include the 7I92s ip address)
sakumar wrote: The Servo time stays at around 105 micro-seconds. So is it OK for me to set the SERVO_PERIOD to 120,000? Is there an advantage to doing this over leaving it at the default 1,000,000?
