7i77 encoders not working
7 years 6 months ago #131599 by Henk
Replied by Henk on topic 7i77 encoders not working
I wonder if an92626 ever found a solution to this problem?
I am facing a similar issue with the machine I'm currently working on. 7i92+7i77 running on 2.7.14 - Debian Stretch. I changed everything around in trying to find the defective wiring/encoder but in cannot get enc0 and enc1 on the 7i77 to work. b input remains dead on those two. I have even changed the a and b inputs on the terminal at the 7i77, and still b phase show nothing. wired a different encoder (new, that I checked on the oscope as well), still nothing on b.
If I plug the same encoders into enc2 - 5, it works as it should.
going to change the 7i77 later today as a sanity check.
Henk
7 years 6 months ago #131611 by PCW
Replied by PCW on topic 7i77 encoders not working
"b" on encoders 0,1 not working suggests a common problem on the
multiplexed "b" signal connection between the 7I77 and the 7I92.
This problem could be either on the 7I77, the cable between the 7I92 and 7I77,
or on the 7I92.
7 years 6 months ago #131629 by Henk
Thanks PCW. I will test some different components to try and isolate the problem.
Henk
7 years 6 months ago #131685 by Henk
So it turned out that the ribbon between the 7i77 and the 7i92 wasn't crimped properly ..
Thanks again for the advice PCW.
Henk
Moderators: PCW, jmelson
Time to create page: 0.170 seconds
