hm2dpll, pin hm2_XiXX.N.encoder.MM.timer-num does not exist.
9 years 7 months ago #90626 by jCandlish
PCW wrote: i would fetch the source from Mesa
How?
9 years 7 months ago #90641 by PCW
Download the 7i80.zip file from Mesa
The complete hm2 source is in configs/hostmot2/source
9 years 7 months ago - 9 years 7 months ago #90677 by jCandlish
Hmm...
Somehow the zipfile is incomplete.
Replacing the 'src' directory of the git clone (where there is a makefile for building a debian package) with the 'configs/hostmot2/source' directory from 7i80.zip ends with:
/usr/bin/make -j --jobserver-fds=3,4 make[1]: Entering directory '/home/installer/Dev/hostmot2-from-github/hostmot2-firmware' scripts/firmwares.py firmwares.txt > fw/firmwares.mk.tmp mv -f fw/firmwares.mk.tmp fw/firmwares.mk make[1]: *** No rule to make target 'src/d8o8.vhd', needed by 'fw/7i80hd16/SVST8_4.BIT'. Stop. make[1]: Leaving directory '/home/installer/Dev/hostmot2-from-github/hostmot2-firmware' debian/rules:5: recipe for target 'build' failed make: *** [build] Error 2 dpkg-buildpackage: error: debian/rules build gave error exit status 2
I am at a loss to know how to correctly modify the makefile containing:
find . -type f -exec grep -nH -e d8o8.vhd {} + ./scripts/build.py:49: 'd8o8.vhd', ./Makefile:12: PinExists.vhd CountPinsInRange.vhd d8o8.vhd dpll.vhd hostmotid.vhd \
Which new vhd file takes the place of the missing d8o8.vhd ?
Last edit: 9 years 7 months ago by jCandlish. Reason: clarity
9 years 7 months ago #90690 by PCW
You could extract the current source list from the appropriate project file (or just use the project file as is)
Moderators: PCW, jmelson
Time to create page: 0.101 seconds
