MESA Card Recommendation
9 years 2 months ago #97829 by PCW
Replied by PCW on topic MESA Card Recommendation
For a simple 3 axis system, I would suggest a 5I25/6I25 (PCI/PCIE) and whatever breakout board you are currently using
If you want an Ethernet connected system I would suggest a 7I92H+ your breakout
Maximum 5I25/6I25 steprate is about 4 MHz, maximum 7I92 steprate is about 10 MHz
9 years 2 months ago #97832 by remrendes
Replied by remrendes on topic MESA Card Recommendation
Thanks! Yes, this is the other on what I looked. 4MHz looks more than enough.
When do I need a doughter card?
9 years 2 months ago #97859 by remrendes
Or not!? For 3000rpm I need 12MHz with the 1000ppr encoder.
9 years 2 months ago #97870 by PCW
3000 RPM with a 1000 PPR encoder (4000 quadrature counts/rev) is a 200 KHz count rate
(50 RPS * 4000)
9 years 2 months ago - 9 years 2 months ago #97874 by remrendes
Ohh, yes, I calculated in minutes. Anyway, I can use the ethernet type with a laptop as well.
Last edit: 9 years 2 months ago by remrendes.
9 years 2 months ago #97880 by PCW
You should be aware that laptops in general do not make good LinuxCNC hosts
This is because they very often have power management hardware/software that cannot be disabled
and that causes large latencies. Some Laptops may be OK or at least OK until you change the backlight brightness
or change from line to battery power etc etc
Moderators: PCW, jmelson
Time to create page: 0.404 seconds
