Basically to make a new configuration for a already existing card, you make a new pinout file
The pinout file determines which modules are built and how they are connected to the physical FPGA pins
If you dont want to install webpack I can build a bit file for you but you would have to supply a pinout file that has your desired pinout (plus I need the target card/FPGA size)
Pinout files all start with PIN and end with NNN.vhd when NNN is the number of GPIO pins of the particular card:
34 = 5I25,6I25,7I92
42 = 4I74
48 = 7I43,7I93
51 = 7I76E,7I96,7I97
68 = 7I80DB
72 = 5I20,5I22,5I23,5I24,6I24,7I80HD,7I90
96 = 5I22
144 = 3X20
