- Thank you received: 183
Mesa 7i92 and IPv6 error
- Mike_Eitel
7 years 6 months ago #130410
by Mike_Eitel
Replied by Mike_Eitel on topic Mesa 7i92 and IPv6 error
A adress 169.254.X.X is quite often related to dhcp problem. Did you set eth0 to static? And do you have only one eth? Normally you need two.
Mike
Mike
- jsflanagan
- Topic Author
7 years 6 months ago #130412
by jsflanagan
Replied by jsflanagan on topic Mesa 7i92 and IPv6 error
Ah yes that seems to be my first issue, I just set it all up on a fresh linuxcnc install and got past that issue. Results from my "ip a" show that the interface is configured to 10.10.10.2 as it should be per the network interfaces file. Linuxcnc then errors out on something different now but it's down to configuration in my HAL file as everything for configuring the card is working! Will post an update once I get the rest of it working. Thanks everyone for the swift help.
Time to create page: 0.097 seconds
