How to check a Mesa 7i76e if it is defective.
7 years 6 months ago #130424 by Edi_48
Hello
I got my Mesa 7i76E early March directly from Mesashop.
I can't get the iHSV57-36 stepper to work.
When I enter data into Linuxcnc 2.8, the pointer goes in the desired direction but
The motors don't move. My Hal and Ini were adapted from the Talla83.
If I measure the outputs X,Y,Z from the map I get the following result.
X Dir + and Dir- 0 Volt and with Step + and Step- also 0 Volt
Y Dir + and Dir- 0,25 Volt and at Step + and Step- 5 Volt
The motors go with a rotary encoder .
Is now my card defect
Hilton
7 years 6 months ago #130461 by rodw
Did you happen to connect 5V to the enable pins on the stepper driver? If you did, remove it as its stepper disable signal.
7 years 6 months ago - 7 years 6 months ago #130470 by PCW
If Step+ and Step- ( or Dir+ and Dir-) are at the same voltage (and they are not shorted externally) This means the output drivers have been damaged, one should always be the opposite of the other ( if +StepN or +DirN is 5V -StepN or -DirN must be 0V and vice versa)
Note that you cannot measure the pins on the green connectors via the screws
on the top of the connectors unless the screws are tight.
Last edit: 7 years 6 months ago by PCW.
7 years 6 months ago #130478 by Edi_48
A cable has been connected to measure
How do I get returns approval to return the card?
7 years 6 months ago #130511 by PCW
Did you measure _between_ the + and - step/dir pins with a voltmeter?
If the result of this measurement is not ~5V or ~-5V when LinuxCNC is idle
then the output drivers have been damaged somehow. If this is the case you can request a RMA number at sales.mesanet.com
7 years 6 months ago #130562 by PCW
Note, I tried to reply to your email to Mesa but it bounced, do you have an email address that works?
Moderators: PCW, jmelson
Time to create page: 0.101 seconds
