Secondary spindle on 7i76e
7 years 6 months ago - 7 years 6 months ago #131758 by tecno
Replied by tecno on topic Secondary spindle on 7i76e
andypugh wrote: A user M-code to switch the control pins of some mux components would be one way to do this.
Alternatively, you could use the output of a "comp" HAL component based on spindle speed.
But, a better way might be to switch on tool-number. For example decide that tools > 50 are in the high-speed spindle. That way the tool XY offsets can account for the different tool positions of the two spindles.
You would pass the spindle speed command to both pwm generators, but only enable one at a time based on tool number.
It's slightly complicated by the fact that tool number is S32, and the comp / wcomp components want a floating point.
loadrt conv_s32_float loadrt wcomp addf conv_s32_float.0 servo-thread addf wcomp.0 servo thread setp wcomp.0.min 49.5 setp wcomp.0.max 49.6 # You probably already have a HAL pin that holds the tool number, use that here. net tool-number conv_s32_float.0.in net tool-number-float conv_s32_float.0.out wcomp.0.in net spindle-slow wcomp.0.under => pwmgen.0.enable net spindle-fast wcomp.0.over -> pwmgen.1.enable net spindle-speed-rpm pwmgen.0.value pwmgen.1.value
Hi Andy,
Interesting this with having tool-number to control spindles.
All I can find as regards tool is in postgui.hal = is something missing?
How is this added to my config? Assuming that the spindle setup I have now will be intact with all whistles and bells.
The new HS spindle only needs on/off and speed setting = no feedback or other whistles and bells.
How is this pwmgen.0. implemented now in my current setup. Trying to understand what is going on.
Cheers
Bengt
File Name: GB_2speed_...-24.comp
File Size:1.44 KB
File Name: GB_2speed.ini
File Size:4.73 KB
File Name: GB_2speed_...4-24.hal
File Size:19.21 KB
File Name: postgui.hal
File Size:770 B
Last edit: 7 years 6 months ago by tecno.
7 years 6 months ago #131771 by andypugh
Replied by andypugh on topic Secondary spindle on 7i76e
tecno wrote: Interesting this with having tool-number to control spindles.
Maybe not, you could try using tool-prep-number.
Or maybe create a new signal and use iocontrol.0.tool−number
re-wire your pwmgen enable as suggested, but don't bother with a secondary pwmgen for the high speed spindle, just net the "over" output direct to the secondary spindle control output.
On further reflection you probably want the wcomp min to be 1 rpm, then use the wcomp.0.out for the normal spindle pwmgen enable.
7 years 6 months ago #131776 by tecno
I am lost here, rewire what to be more exact?
7 years 6 months ago #131778 by andypugh
Well, as you don't have any pwmgens I can see your confusion.
How about adding an extra output to your GB-2speed.comp that sets a second output pin high if speed > (some number) and sets the current spindle enable pin to false in that situation?
... pin out bit high-speed-spindle-enable-out; ... if (spindle_speed_in == 0){ spindle-enable-out = 0; high-speed-spindle-enable-out = 0; return; } if (spindle_speed_in > 20000){ spindle-enable-out = 0; high-speed-spindle-enable-out = 1; return; } ...
7 years 6 months ago #131781 by tecno
Looks to be a simple solution to modify the COMP
component GB_2speed HS; pin in bit spindle-enable-in; pin out bit spindle-enable-out; pin in float spindle-speed-in; pin out float motor-speed-out; pin out bit high-speed-spindle-enable-out; pin in bit gear-high; pin in bit motor-high; pin in bit gear-A; pin in bit gear-B; pin in bit gear-C; pin in bit gear-D; pin in bit gear-E; pin out unsigned gear-required; pin out bit message-##[14]; license "gpl"; function _; ;; FUNCTION(_){ int actual, message; int i; // These need to be edited to suit the gearbox int speeds[15] = {0, 80, 125, 160, 215, 270, 360, 450, 595, 750, 1000, 1191, 1500, 2500, 0x1P30}; int reqd_gear[15] = {0x0, 0x01, 0x21, 0x02, 0x22, 0x04, 0x24, 0x08, 0x28, 0x10, 0x48, 0x68, 0x50, 0x70, 0x0}; if (spindle_speed_in == 0){ spindle-enable-out = 0; high-speed-spindle-enable-out = 0; return; } if (spindle_speed_in > 12000){ spindle-enable-out = 0; high-speed-spindle-enable-out = 1; return; } actual = (gear_high * 0x40 + motor_high * 0x20 + gear_A * 0x10 + gear_B * 0x08 + gear_C * 0x04 + gear_D * 0x02 + gear_E * 0x01); for (i = 0; spindle_speed_in > speeds[i] && i < 14; i++); gear_required = reqd_gear[i]; if (gear_required == actual && gear_required != 0x0){ // We are in the right gear spindle_enable_out = spindle_enable_in; motor_speed_out = speeds[13] * (spindle_speed_in / speeds[i]); message = 0; } else { int j; motor_speed_out = 0; spindle_enable_out = 0; for (j = 0; j < 13; j++) { message(j) = 0; } message(i) = 1; } }
From where do I get the 0-10V to the HS inverter? 7i76e P2 pin 1 IO34?
7 years 6 months ago #131783 by andypugh
I seem to be confusing my threads. I was under the impression that this was a simple on/off spindle, but reading back it isn't.
Your BoB on the second connector needs a PWM. Does your current firmware put that on the right pin?
Moderators: PCW, jmelson
Time to create page: 0.154 seconds
