Best Ethernet Based Board in 2020
6 years 4 months ago #170309 by rodw
NO for CNC you need to use their SD (step and direction) drives so they can be controlled by Linuxcnc (or other similar systems.
Those are designed for industrial use, convyers etc.
6 years 4 months ago #170311 by EverydayDiesel
Other then switching to the SD drives, does everything else look ok?
6 years 4 months ago #170312 by Nitram
I used a 7i76e on a lathe build.
The attached pdf helped immensely.
The following user(s) said Thank You: Ozcnc, deanforbes, EverydayDiesel
6 years 4 months ago - 6 years 4 months ago #170719 by EverydayDiesel
rodw wrote: NO for CNC you need to use their SD (step and direction) drives so they can be controlled by Linuxcnc (or other similar systems.
You were right. I reached out to the company with several questions and this was the response...
I'm an applications engineer with Teknic. I was recently forwarded your contact request regarding the differences between the SC and SD ClearPath servo motors.
In short - you can use SC motors to take in step and direction, but I wouldn't recommend it. The MES 717rE should be a pretty good fit (I have seen customers use it in the past, and LinuxCNC is a good choice for the CNC control software.
That being said, if you are looking for the motor drive to interface with step and direction signals (generated by the G-code), it's best to use a CNC software that is configured to accept the signals CNC controllers generally output. Creating your own trajectory generator that interfaces with G-code is a non-trivial task, although it is possible to do so.
Essentially, the SD motors come configured to work in CNC applications with little programming (other than configuration) with the motors themselves. They simple wire to a controller and breakout-board. The SC motors can take in step and direction commands, but you would need to program the operational mode completely from scratch. With that, you would also need to setup a host PC (single board computer) that interfaces with serial communication in order to input the step and direction signals into the motor inputs.
Last edit: 6 years 4 months ago by EverydayDiesel.
Moderators: PCW, jmelson
Time to create page: 0.212 seconds
