- Thank you received: 4
Charge pump from Mesa 7i96 in 4+1 config?
6 years 4 months ago - 6 years 4 months ago #170376
by msageryd
Replied by msageryd on topic Charge pump from Mesa 7i96 in 4+1 config?
Wohoo!
At last I can see the frequency in the oscilloscope. Unfortunately, I don't know what I did. I simply restarted LCNC and halcmd. After issuing the exact same commands again it works.
Last edit: 6 years 4 months ago by msageryd.
6 years 4 months ago #172275
by Zacharius
Replied by Zacharius on topic Charge pump from Mesa 7i96 in 4+1 config?
hello,
don't you mind to share full hal file for 7i96+7i73?
i'm struggling to get MPG controller working
linuxcnc drops message like Pin 'hm2_7i96.0.7i73.0.1.input-03' does not exist
appreciate any clue on that.
6 years 4 months ago #172295
Replied by PCW on topic Charge pump from Mesa 7i96 in 4+1 config?
Did you list the available hardware pins?
with
halcmd show pin hm2*
(when linuxcnc is running)
with
The following user(s) said Thank You: Zacharius
6 years 4 months ago - 6 years 4 months ago #172301
by Zacharius
Sure, this example above is how pncconf created example pin in hal.- linuxcnc 2.9
basically what want to achieve there (connected to 7i73) is 2004 LCD + axis selector (multi position switch) + increment selector (multi position switch) + 11 buttons + 100ppr hand wheel for all axes
here is the output from command
and i probably see the issue
hm2_7i96.0.7i73.0.0.input-03
which helped a bit but still have no blind idea how to setup LCD to work and join all the things together
7i73 in 4x8keypad + lcd mode by jumpers
LCD, handwheel are connected as per manual
olo@debian:~$ halcmd show pin hm2
Component Pins:
Owner Type Dir Value Name
26 s32 OUT 2097400000 hm2_7i96.0.0.debug
26 u32 IN 0x00000000 hm2_7i96.0.7i73.0.0.display
26 s32 OUT 1 hm2_7i96.0.7i73.0.0.enc0.count
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc0.index-enable
26 float OUT 1 hm2_7i96.0.7i73.0.0.enc0.position
26 s32 OUT 1 hm2_7i96.0.7i73.0.0.enc0.rawcounts
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc0.reset
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc1.count
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc1.index-enable
26 float OUT 0 hm2_7i96.0.7i73.0.0.enc1.position
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc1.rawcounts
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc1.reset
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc2.count
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc2.index-enable
26 float OUT 0 hm2_7i96.0.7i73.0.0.enc2.position
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc2.rawcounts
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc2.reset
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc3.count
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc3.index-enable
26 float OUT 0 hm2_7i96.0.7i73.0.0.enc3.position
26 s32 OUT 0 hm2_7i96.0.7i73.0.0.enc3.rawcounts
26 bit I/O FALSE hm2_7i96.0.7i73.0.0.enc3.reset
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-00
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-00-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-01
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-01-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-02
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-02-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-03
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-03-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-04
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-04-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-05
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-05-not
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-06
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-06-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-07
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-07-not
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-08
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-08-not
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-09
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-09-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-10
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-10-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-11
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-11-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-12
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-12-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-13
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-13-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-14
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-14-not
26 bit OUT TRUE hm2_7i96.0.7i73.0.0.input-15
26 bit OUT FALSE hm2_7i96.0.7i73.0.0.input-15-not
26 u32 OUT 0x00000040 hm2_7i96.0.7i73.0.0.keycode
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-00
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-01
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-02
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-03
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-04
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-05
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-06
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-07
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-08
26 bit IN FALSE hm2_7i96.0.7i73.0.0.output-09
26 float IN 100 hm2_7i96.0.dpll.01.timer-us
26 float IN 100 hm2_7i96.0.dpll.02.timer-us
26 float IN 100 hm2_7i96.0.dpll.03.timer-us
26 float IN 100 hm2_7i96.0.dpll.04.timer-us
26 float IN 0.7692308 hm2_7i96.0.dpll.base-freq-khz
26 u32 OUT 0x0000002A hm2_7i96.0.dpll.ddsize
26 float OUT -0.9942497 hm2_7i96.0.dpll.phase-error-us
26 u32 IN 0x00400000 hm2_7i96.0.dpll.plimit
26 u32 OUT 0x0000001F hm2_7i96.0.dpll.prescale
26 u32 IN 0x000007D0 hm2_7i96.0.dpll.time-const
26 bit OUT TRUE hm2_7i96.0.gpio.000.in ==> min-home-x
26 bit OUT FALSE hm2_7i96.0.gpio.000.in_not
26 bit IN FALSE hm2_7i96.0.gpio.000.out
26 bit OUT TRUE hm2_7i96.0.gpio.001.in ==> min-home-y
26 bit OUT FALSE hm2_7i96.0.gpio.001.in_not
26 bit IN FALSE hm2_7i96.0.gpio.001.out
26 bit OUT TRUE hm2_7i96.0.gpio.002.in ==> max-home-z
26 bit OUT FALSE hm2_7i96.0.gpio.002.in_not
26 bit IN FALSE hm2_7i96.0.gpio.002.out
26 bit OUT FALSE hm2_7i96.0.gpio.003.in ==> max-x
26 bit OUT TRUE hm2_7i96.0.gpio.003.in_not
26 bit IN FALSE hm2_7i96.0.gpio.003.out
26 bit OUT TRUE hm2_7i96.0.gpio.004.in ==> max-y
26 bit OUT FALSE hm2_7i96.0.gpio.004.in_not
26 bit IN FALSE hm2_7i96.0.gpio.004.out
26 bit OUT TRUE hm2_7i96.0.gpio.005.in ==> min-z
26 bit OUT FALSE hm2_7i96.0.gpio.005.in_not
26 bit IN FALSE hm2_7i96.0.gpio.005.out
26 bit OUT TRUE hm2_7i96.0.gpio.006.in ==> home-a
26 bit OUT FALSE hm2_7i96.0.gpio.006.in_not
26 bit IN FALSE hm2_7i96.0.gpio.006.out
26 bit OUT TRUE hm2_7i96.0.gpio.007.in ==> estop-ext
26 bit OUT FALSE hm2_7i96.0.gpio.007.in_not
26 bit IN FALSE hm2_7i96.0.gpio.007.out
26 bit OUT FALSE hm2_7i96.0.gpio.008.in
26 bit OUT TRUE hm2_7i96.0.gpio.008.in_not
26 bit IN FALSE hm2_7i96.0.gpio.008.out
26 bit OUT FALSE hm2_7i96.0.gpio.009.in
26 bit OUT TRUE hm2_7i96.0.gpio.009.in_not
26 bit IN FALSE hm2_7i96.0.gpio.009.out
26 bit OUT FALSE hm2_7i96.0.gpio.010.in
26 bit OUT TRUE hm2_7i96.0.gpio.010.in_not
26 bit IN FALSE hm2_7i96.0.gpio.010.out
26 bit OUT TRUE hm2_7i96.0.gpio.011.in
26 bit OUT FALSE hm2_7i96.0.gpio.011.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.012.in
26 bit OUT FALSE hm2_7i96.0.gpio.012.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.013.in
26 bit OUT FALSE hm2_7i96.0.gpio.013.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.014.in
26 bit OUT FALSE hm2_7i96.0.gpio.014.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.015.in
26 bit OUT FALSE hm2_7i96.0.gpio.015.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.016.in
26 bit OUT FALSE hm2_7i96.0.gpio.016.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.017.in
26 bit OUT TRUE hm2_7i96.0.gpio.017.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.018.in
26 bit OUT TRUE hm2_7i96.0.gpio.018.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.019.in
26 bit OUT TRUE hm2_7i96.0.gpio.019.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.020.in
26 bit OUT TRUE hm2_7i96.0.gpio.020.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.021.in
26 bit OUT TRUE hm2_7i96.0.gpio.021.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.022.in
26 bit OUT TRUE hm2_7i96.0.gpio.022.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.023.in
26 bit OUT TRUE hm2_7i96.0.gpio.023.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.024.in
26 bit OUT TRUE hm2_7i96.0.gpio.024.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.025.in
26 bit OUT FALSE hm2_7i96.0.gpio.025.in_not
26 bit IN FALSE hm2_7i96.0.gpio.025.out
26 bit OUT TRUE hm2_7i96.0.gpio.026.in
26 bit OUT FALSE hm2_7i96.0.gpio.026.in_not
26 bit IN FALSE hm2_7i96.0.gpio.026.out
26 bit OUT FALSE hm2_7i96.0.gpio.027.in
26 bit OUT TRUE hm2_7i96.0.gpio.027.in_not
26 bit IN FALSE hm2_7i96.0.gpio.027.out
26 bit OUT FALSE hm2_7i96.0.gpio.028.in
26 bit OUT TRUE hm2_7i96.0.gpio.028.in_not
26 bit IN FALSE hm2_7i96.0.gpio.028.out
26 bit OUT FALSE hm2_7i96.0.gpio.029.in
26 bit OUT TRUE hm2_7i96.0.gpio.029.in_not
26 bit IN FALSE hm2_7i96.0.gpio.029.out
26 bit OUT TRUE hm2_7i96.0.gpio.030.in
26 bit OUT FALSE hm2_7i96.0.gpio.030.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.031.in
26 bit OUT FALSE hm2_7i96.0.gpio.031.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.032.in
26 bit OUT TRUE hm2_7i96.0.gpio.032.in_not
26 bit OUT FALSE hm2_7i96.0.gpio.033.in
26 bit OUT TRUE hm2_7i96.0.gpio.033.in_not
26 bit OUT TRUE hm2_7i96.0.gpio.034.in
26 bit OUT FALSE hm2_7i96.0.gpio.034.in_not
26 bit IN FALSE hm2_7i96.0.gpio.034.out
26 bit OUT TRUE hm2_7i96.0.gpio.035.in
26 bit OUT FALSE hm2_7i96.0.gpio.035.in_not
26 bit IN FALSE hm2_7i96.0.gpio.035.out
26 bit OUT TRUE hm2_7i96.0.gpio.036.in
26 bit OUT FALSE hm2_7i96.0.gpio.036.in_not
26 bit IN FALSE hm2_7i96.0.gpio.036.out
26 bit OUT TRUE hm2_7i96.0.gpio.037.in
26 bit OUT FALSE hm2_7i96.0.gpio.037.in_not
26 bit IN FALSE hm2_7i96.0.gpio.037.out
26 bit OUT TRUE hm2_7i96.0.gpio.038.in
26 bit OUT FALSE hm2_7i96.0.gpio.038.in_not
26 bit IN FALSE hm2_7i96.0.gpio.038.out
26 bit OUT TRUE hm2_7i96.0.gpio.039.in
26 bit OUT FALSE hm2_7i96.0.gpio.039.in_not
26 bit IN FALSE hm2_7i96.0.gpio.039.out
26 bit OUT TRUE hm2_7i96.0.gpio.040.in
26 bit OUT FALSE hm2_7i96.0.gpio.040.in_not
26 bit IN FALSE hm2_7i96.0.gpio.040.out
26 bit OUT TRUE hm2_7i96.0.gpio.041.in
26 bit OUT FALSE hm2_7i96.0.gpio.041.in_not
26 bit IN FALSE hm2_7i96.0.gpio.041.out
26 bit OUT TRUE hm2_7i96.0.gpio.042.in
26 bit OUT FALSE hm2_7i96.0.gpio.042.in_not
26 bit IN FALSE hm2_7i96.0.gpio.042.out
26 bit OUT TRUE hm2_7i96.0.gpio.043.in
26 bit OUT FALSE hm2_7i96.0.gpio.043.in_not
26 bit IN FALSE hm2_7i96.0.gpio.043.out
26 bit OUT TRUE hm2_7i96.0.gpio.044.in
26 bit OUT FALSE hm2_7i96.0.gpio.044.in_not
26 bit IN FALSE hm2_7i96.0.gpio.044.out
26 bit OUT TRUE hm2_7i96.0.gpio.045.in
26 bit OUT FALSE hm2_7i96.0.gpio.045.in_not
26 bit IN FALSE hm2_7i96.0.gpio.045.out
26 bit OUT TRUE hm2_7i96.0.gpio.046.in
26 bit OUT FALSE hm2_7i96.0.gpio.046.in_not
26 bit IN FALSE hm2_7i96.0.gpio.046.out
26 bit OUT TRUE hm2_7i96.0.gpio.047.in
26 bit OUT FALSE hm2_7i96.0.gpio.047.in_not
26 bit IN FALSE hm2_7i96.0.gpio.047.out
26 bit OUT TRUE hm2_7i96.0.gpio.048.in
26 bit OUT FALSE hm2_7i96.0.gpio.048.in_not
26 bit IN FALSE hm2_7i96.0.gpio.048.out
26 bit OUT TRUE hm2_7i96.0.gpio.049.in
26 bit OUT FALSE hm2_7i96.0.gpio.049.in_not
26 bit IN FALSE hm2_7i96.0.gpio.049.out
26 bit OUT TRUE hm2_7i96.0.gpio.050.in
26 bit OUT FALSE hm2_7i96.0.gpio.050.in_not
26 bit IN FALSE hm2_7i96.0.gpio.050.out
26 bit IN FALSE hm2_7i96.0.led.CR01
26 bit IN FALSE hm2_7i96.0.led.CR02
26 bit IN FALSE hm2_7i96.0.led.CR03
26 bit IN FALSE hm2_7i96.0.led.CR04
26 bit OUT FALSE hm2_7i96.0.packet-error
26 bit OUT FALSE hm2_7i96.0.packet-error-exceeded
26 s32 OUT 0 hm2_7i96.0.packet-error-level
26 s32 OUT 0 hm2_7i96.0.read-request.time
26 s32 OUT 724273 hm2_7i96.0.read.time
26 u32 OUT 0x00000000 hm2_7i96.0.sserial.port-0.fault-count
26 u32 OUT 0x00000003 hm2_7i96.0.sserial.port-0.port_state
26 u32 OUT 0x00000000 hm2_7i96.0.sserial.port-0.port_state2
26 u32 OUT 0x00000000 hm2_7i96.0.sserial.port-0.port_state3
26 bit IN TRUE hm2_7i96.0.sserial.port-0.run
26 bit IN FALSE hm2_7i96.0.ssr.00.out-00
26 bit IN FALSE hm2_7i96.0.ssr.00.out-01
26 bit IN FALSE hm2_7i96.0.ssr.00.out-02
26 bit IN FALSE hm2_7i96.0.ssr.00.out-03
26 bit IN FALSE hm2_7i96.0.ssr.00.out-04
26 bit IN FALSE hm2_7i96.0.ssr.00.out-05
26 u32 IN 0x000F4240 hm2_7i96.0.ssr.00.rate
26 bit IN TRUE hm2_7i96.0.stepgen.00.control-type
26 s32 OUT 0 hm2_7i96.0.stepgen.00.counts
26 float OUT 0 hm2_7i96.0.stepgen.00.dbg_err_at_match
26 float OUT 0 hm2_7i96.0.stepgen.00.dbg_ff_vel
26 float OUT 0 hm2_7i96.0.stepgen.00.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i96.0.stepgen.00.dbg_s_to_match
26 s32 OUT 0 hm2_7i96.0.stepgen.00.dbg_step_rate
26 float OUT 0 hm2_7i96.0.stepgen.00.dbg_vel_error
26 bit IN FALSE hm2_7i96.0.stepgen.00.enable <== x-enable
26 float IN 0 hm2_7i96.0.stepgen.00.position-cmd
26 float OUT -0 hm2_7i96.0.stepgen.00.position-fb ==> x-pos-fb
26 float IN 0 hm2_7i96.0.stepgen.00.velocity-cmd <== x-output
26 float OUT 0 hm2_7i96.0.stepgen.00.velocity-fb
26 bit IN TRUE hm2_7i96.0.stepgen.01.control-type
26 s32 OUT 0 hm2_7i96.0.stepgen.01.counts
26 float OUT 0 hm2_7i96.0.stepgen.01.dbg_err_at_match
26 float OUT 0 hm2_7i96.0.stepgen.01.dbg_ff_vel
26 float OUT 0 hm2_7i96.0.stepgen.01.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i96.0.stepgen.01.dbg_s_to_match
26 s32 OUT 0 hm2_7i96.0.stepgen.01.dbg_step_rate
26 float OUT 0 hm2_7i96.0.stepgen.01.dbg_vel_error
26 bit IN FALSE hm2_7i96.0.stepgen.01.enable <== y-enable
26 float IN 0 hm2_7i96.0.stepgen.01.position-cmd
26 float OUT -0 hm2_7i96.0.stepgen.01.position-fb ==> y-pos-fb
26 float IN 0 hm2_7i96.0.stepgen.01.velocity-cmd <== y-output
26 float OUT 0 hm2_7i96.0.stepgen.01.velocity-fb
26 bit IN TRUE hm2_7i96.0.stepgen.02.control-type
26 s32 OUT 0 hm2_7i96.0.stepgen.02.counts
26 float OUT 0 hm2_7i96.0.stepgen.02.dbg_err_at_match
26 float OUT 0 hm2_7i96.0.stepgen.02.dbg_ff_vel
26 float OUT 0 hm2_7i96.0.stepgen.02.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i96.0.stepgen.02.dbg_s_to_match
26 s32 OUT 0 hm2_7i96.0.stepgen.02.dbg_step_rate
26 float OUT 0 hm2_7i96.0.stepgen.02.dbg_vel_error
26 bit IN FALSE hm2_7i96.0.stepgen.02.enable <== z-enable
26 float IN 0 hm2_7i96.0.stepgen.02.position-cmd
26 float OUT 0 hm2_7i96.0.stepgen.02.position-fb ==> z-pos-fb
26 float IN 0 hm2_7i96.0.stepgen.02.velocity-cmd <== z-output
26 float OUT 0 hm2_7i96.0.stepgen.02.velocity-fb
26 bit IN FALSE hm2_7i96.0.stepgen.03.control-type
26 s32 OUT 0 hm2_7i96.0.stepgen.03.counts
26 float OUT 0 hm2_7i96.0.stepgen.03.dbg_err_at_match
26 float OUT 0 hm2_7i96.0.stepgen.03.dbg_ff_vel
26 float OUT 0 hm2_7i96.0.stepgen.03.dbg_pos_minus_prev_cmd
26 float OUT 0 hm2_7i96.0.stepgen.03.dbg_s_to_match
26 s32 OUT 0 hm2_7i96.0.stepgen.03.dbg_step_rate
26 float OUT 0 hm2_7i96.0.stepgen.03.dbg_vel_error
26 bit IN FALSE hm2_7i96.0.stepgen.03.enable
26 float IN 0 hm2_7i96.0.stepgen.03.position-cmd
26 float OUT 0 hm2_7i96.0.stepgen.03.position-fb
26 float IN 0 hm2_7i96.0.stepgen.03.velocity-cmd
26 float OUT 0 hm2_7i96.0.stepgen.03.velocity-fb
26 s32 IN -1 hm2_7i96.0.stepgen.timer-number
26 bit I/O FALSE hm2_7i96.0.watchdog.has_bit
26 s32 OUT 39479 hm2_7i96.0.write.time
Last edit: 6 years 4 months ago by Zacharius.
6 years 4 months ago #172360
To use the LCD you would normally use the lcd component
man lcd
for the keypad, the matrix_kb component would be used
man matrix_kb
man lcd
man matrix_kb
6 years 4 months ago - 6 years 4 months ago #172371
by Zacharius
sorry i'm not a developer and these things are really not trivial.
anyway probably found good example which i wasn't able to find yesterday via regular search.
may be it will help somebody else.
forum.linuxcnc.org/47-hal-examples/32725...nt-with-7i73?start=0
Time to create page: 0.188 seconds
