5i24-16 + 7i52S + 7i44
4 years 10 months ago - 4 years 10 months ago #228407 by highbiker
Replied by highbiker on topic 5i24-16 + 7i52S + 7i44
As you said: Third ones a charm. The last bit file is working as intended. Thanks a lot!!
Last edit: 4 years 10 months ago by highbiker.
4 years 3 months ago #246452 by zoni
Replied by zoni on topic 5i24-16 + 7i52S + 7i44
hi have you successfully install 7i52s with 5i24 if yes can you attach you config files
4 years 3 months ago #246496 by andypugh
Replied by andypugh on topic 5i24-16 + 7i52S + 7i44
The 7i52S is (as far as I am aware) an entirely passive card. So even users of other cards with the 5u24 might be able to help.
Do you have a specific question? (I am using a 5i24 on my lathe, but with a 7i49 rather than 7i52)
The following user(s) said Thank You: Deckerjwd
3 years 8 months ago #263786 by Deckerjwd
Replied by Deckerjwd on topic 5i24-16 + 7i52S + 7i44
Im running the same setup but i have a 5i24-25 card, is the 16 bit file compatible?
3 years 8 months ago #263787 by PCW
Replied by PCW on topic 5i24-16 + 7i52S + 7i44
No, you need an image built for the -25 FPGA
3 years 8 months ago #263788 by Deckerjwd
is the 5i24_25_sssvst_6_12_6_7i52s_7i52d.bit the right one, for a 5i24-25, 7i52d and 7i44?
Moderators: PCW, jmelson
Time to create page: 0.266 seconds
