7i97 no ethernet connection
4 years 11 months ago - 4 years 11 months ago #228050 by PCW
Replied by PCW on topic 7i97 no ethernet connection
The LEDS are in the expected states
Looks like there's extra text on line 225 of the hal file
"[SPINDLE_0]OUTPUT_SCALE"
Deleting that line should fix the "unknown command" error
The "cannot gain I/O privileges" and "using POSIX non-realtime" errors
are caused by some installation problem. How did you install LinuxCNC?
Last edit: 4 years 11 months ago by PCW.
4 years 11 months ago #228053 by Arnold
Replied by Arnold on topic 7i97 no ethernet connection
Thanks!
#[SPINDLE_0]OUTPUT_SCALE
it let Linuxcnc to start, but it takes long very long time, and seems unstable
red light again
I got linuxcnc from:  linuxcnc.org/downloads/
I selected:
4 years 11 months ago #228055 by Arnold
What do you think I could do wrong?
Doing a new fresh installation, ¿could you give me any advice to do it right?
4 years 11 months ago #228064 by PCW
Not sure what's broken on your installation, but "cannot gain I/O privileges"
is a show-stopper (unless you just want to run in simulation mode)
The hang is likely because in the ini file:
[TASK]
TASK = milltask
CYCLE_TIME = 100
Should be changed to:
[TASK]
TASK = milltask
CYCLE_TIME = 0.100
(there was a change in the interpretation of these timing values
at some point so 100 used to mean 100 ms but now means 100 seconds)
The following user(s) said Thank You: Arnold
4 years 11 months ago #228089 by Arnold
Attach the files here, not on a third party website.
Now you have everything set up properly, except you are using a generic kernel that does not work for machine control.
And it looks like you have Intel ethernet, but we'll get back to it later.
First, what does
uname -a
say?
I have made a new install again: LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO
arnold@cnchp:~$ uname -v #1 SMP PREEMPT RT Debian 4.19.194-2 (2021-06-21) arnold@cnchp:~$ uname -a Linux cnchp 4.19.0-17-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.194-2 (2021-06-21) x86_64 GNU/Linux arnold@cnchp:~$
It is Ok?
4 years 11 months ago #228090 by Arnold
[TASK]
TASK = milltask
CYCLE_TIME = 100
[TASK]
TASK = milltask
CYCLE_TIME = 0.100
New Install, and CYCLE TIME corrected as you mentioned.
Things start to improve image missing /media/kunena/emoticons/smile.png
Thanks!!
Moderators: PCW, jmelson
Time to create page: 0.169 seconds
