6i25 custom firmware and weird latency
4 years 8 months ago #233976 by PCW
I'll see if I can duplicate this here. Still sounds like bad hardware (Either 6I25 or PC)
4 years 8 months ago #233978 by jpa
Actually it is not related to PWMBDirPin. I just had pwmgen.output-type 2, so it didn't output anything until B pin was present. If I set output-type to 1 or value to -0.5, the latency problem starts as soon as I have a PWM output pin.
Seems like it may be some kind of EMI problem caused by the PWM output. Weird though, considering I don't even have any cables connected.
4 years 8 months ago #233980 by jpa
Definite correlation with PWM frequency, if I raise it from 40 kHz to the 390 kHz maximum, the latency effects start occurring multiple times per second.
I guess I'll try another PC next, and maybe try to scope the power lines or something. Though it feels weird that toggling an IO pin that is just connected to a few centimeters of PCB trace and has slew rate set to slow would cause so much EMI.
4 years 8 months ago #233981 by PCW
A shorted GPIO might cause that kind of an issue. You might verify that all GPIO
are at 5V when linuxCNC is not running
4 years 8 months ago #233983 by jpa
Thanks, I'll check that also. Though the problem appears to occur no matter which GPIO I use for the PWM so it's probably not that. The PWM output also appears to work correctly.
I'll report back next week on my findings :)
4 years 8 months ago #234636 by jpa
Looks like it was a bad PC after all.
Trying the other PCIe slots on the motherboard, it crashed the whole PC immediately.
I measured the +12V and +3.3V voltages on the PCIe connector, but they both looked fine.
Probably some poor EMI-sensitive design on the motherboard.
Anyway, I got another PC and now it works fine with the same configurations.
Thanks for the troubleshooting help!
(For future reference, the bad PC was Fujitsu Esprimo E500 E85+)
Moderators: PCW, jmelson
