- Thank you received: 216
need hardware recommendations full sheet plywood router
- robertspark
4 years 5 months ago #242054
by robertspark
Replied by robertspark on topic need hardware recommendations full sheet plywood router
I know I've seen a few different vertical plasma table designs, but they have no cutting forces, so the forces relative to cut direction would be the same and relatively easy (the same) to compensate for.
I am aware that that specific manufacturer did not I believe have a good reputation although I suspect it was to do with support and not that the table did not work in principle.
Sorry I've never seen one in the flesh, keen to see any progress you make
4 years 5 months ago #242077
by tater1337
Replied by tater1337 on topic need hardware recommendations full sheet plywood router
shhh, the plasma cutter is the project after this project, which is really after the other wood router project I posted elsewhere
4 years 5 months ago #242124
Replied by andypugh on topic need hardware recommendations full sheet plywood router
I see no reason that a vertical router wouldn't work. Especially one with a vacuum bed.
Or how about a very strong vacuum bed and use the ceiling as the spoilboard
4 years 5 months ago #242155
by Clive S
Replied by Clive S on topic need hardware recommendations full sheet plywood router
A bit like this:-
The following user(s) said Thank You: robertspark
- robertspark
4 years 5 months ago - 4 years 5 months ago #242156
by robertspark
love the "big t*t on top, oh sh!te button"....
pity about the controller (csmio)...
nice bit of kit
nice bit of kit
Last edit: 4 years 5 months ago by robertspark.
4 years 5 months ago #242179
by Clive S
He has also built a similar 10x5 with full vac table with about 6 Zones
nice bit of kit
Time to create page: 0.293 seconds
