I've restored my virtual machine again, so it's a fresh install of linuxcnc. Now it works when I specifically run python3
$ sudo apt-get install wget
$ sudo apt-get install python3-pip
$ sudo apt-get install git
$ pip3 install --user meson ninja
$ mkdir LiteX
$ cd LiteX
$ wget
raw.githubusercontent.com/enjoy-digital/...aster/litex_setup.py
$ python3 litex_setup.py --init --install --config=standard --gcc=riscv
$ cd ..
$ wget
github.com/YosysHQ/oss-cad-suite-build/r...nux-x64-20220920.tgz
$ tar -xvf oss-cad-suite-linux-x64-20220920.tgz
$ mkdir -p ~/bin
$ ln -s ~/oss-cad-suite/bin/* ~/bin/
#start a new bash, so ~/bin is added to the PATH
$ bash --login
$ git clone
github.com/Peter-van-Tol/LiteX-CNC.git
$ cd LiteX-CNC
$ git checkout stepgen_improvement
$ pip3 install -r requirements.txt
$ python3 -m firmware examples/5a-75e.json
<module 'firmware' from '/home/cedric/LiteX-CNC/firmware/__init__.py'>
Generated fingerprint (CRC): 2614875155
INFO:SoC: __ _ __ _ __
INFO:SoC: / / (_) /____ | |/_/
INFO:SoC: / /__/ / __/ -_)> <
INFO:SoC: /____/_/\__/\__/_/|_|
INFO:SoC: Build your hardware, easily!
INFO:SoC:
INFO:SoC:Creating SoC... (2022-09-28 01:26:07)
INFO:SoC:
INFO:SoC:FPGA device : LFE5U-25F-6BG256C.
INFO:SoC:System clock: 50.000MHz.
INFO:SoCBusHandler:Creating Bus Handler...
INFO:SoCBusHandler:32-bit wishbone Bus, 4.0GiB Address Space.
INFO:SoCBusHandler:Adding reserved Bus Regions...
INFO:SoCBusHandler:Bus Handler created.
INFO:SoCCSRHandler:Creating CSR Handler...
INFO:SoCCSRHandler:32-bit CSR Bus, 32-bit Aligned, 16.0KiB Address Space, 2048B Paging, big Ordering (Up to 32 Locations).
INFO:SoCCSRHandler:Adding reserved CSRs...
INFO:SoCCSRHandler:CSR Handler created.
INFO:SoCIRQHandler:Creating IRQ Handler...
INFO:SoCIRQHandler:IRQ Handler (up to 32 Locations).
INFO:SoCIRQHandler:Adding reserved IRQs...
INFO:SoCIRQHandler:IRQ Handler created.
INFO:SoC:
INFO:SoC:Initial SoC:
INFO:SoC:
INFO:SoC:32-bit wishbone Bus, 4.0GiB Address Space.
INFO:SoC:32-bit CSR Bus, 32-bit Aligned, 16.0KiB Address Space, 2048B Paging, big Ordering (Up to 32 Locations).
INFO:SoC:IRQ Handler (up to 32 Locations).
INFO:SoC:
INFO:SoC:Controller ctrl added.
INFO:SoC:CPU None added.
INFO:SoC:CPU None adding IO Region 0 at 0x00000000 (Size: 0x100000000).
INFO:SoCBusHandler:io0 Region added at Origin: 0x00000000, Size: 0x100000000, Mode: RW, Cached: False Linker: False.
INFO:ECP5PLL:Creating ECP5PLL.
INFO:ECP5PLL:Registering Single Ended ClkIn of 25.00MHz.
INFO:ECP5PLL:Creating ClkOut0 sys of 50.00MHz (+-10000.00ppm).
INFO:ECP5PLL:Creating ClkOut1 sys_ps of 50.00MHz (+-10000.00ppm).
INFO:SoCBusHandler:master0 added as Bus Master.
INFO:SoC:CSR Bridge csr added.
INFO:SoCBusHandler:csr Region added at Origin: 0x00000000, Size: 0x00010000, Mode: RW, Cached: False Linker: False.
INFO:SoCBusHandler:csr added as Bus Slave.
INFO:SoCCSRHandler:csr added as CSR Master.
INFO:SoCBusHandler:Interconnect: InterconnectPointToPoint (1 <-> 1).
INFO:SoCCSRHandler:MMIO_inst CSR allocated at Location 0.
INFO:SoCCSRHandler:ctrl CSR allocated at Location 1.
INFO:SoCCSRHandler:ethphy CSR allocated at Location 2.
INFO:SoCCSRHandler:identifier_mem CSR allocated at Location 3.
INFO:SoC:
INFO:SoC:Finalized SoC:
INFO:SoC:
IO Regions: (1)
io0 : Origin: 0x00000000, Size: 0x100000000, Mode: RW, Cached: False Linker: False
Bus Regions: (1)
csr : Origin: 0x00000000, Size: 0x00010000, Mode: RW, Cached: False Linker: False
Bus Masters: (1)
- master0
Bus Slaves: (1)
- csr
CSR Locations: (4)
- MMIO_inst : 0
- ctrl : 1
- ethphy : 2
- identifier_mem : 3
INFO:SoC:
INFO:ECP5PLL:Config:
clki_div : 1
clkfb : 2
clko0_freq : 50.00MHz
clko0_div : 8
clko0_phase: 0.00°
clko1_freq : 50.00MHz
clko1_div : 8
clko1_phase: 180.00°
clko2_div : 1
vco : 400.00MHz
clkfb_div : 16
cedric@mill:~/LiteX-CNC$
The generated files are in 5a-75e:
$ cd 5a-75e/
$ find
./software
./software/include
./software/include/generated
./software/include/generated/soc.h
./software/include/generated/mem.h
./software/include/generated/git.h
./software/include/generated/csr.h
./gateware
./gateware/colorlight_5a_75e.lpf
./gateware/colorlight_5a_75e.ys
./gateware/colorlight_5a_75e_mem.init
./gateware/build_colorlight_5a_75e.sh
./gateware/colorlight_5a_75e.v
./csr.csv
The .lpf file can be flashed into the FPGA
