Request for Mesa 5i23_7i48_7i52 firmware
2 years 11 months ago #286255 by freemoore
Ah OK.
I've just checked the site and didn't realise that just buying an additional 7i52/7i52s or other daughtercard might be the easiest route when I come to need those additional steppers, I'd forgotten that they're not so expensive.
Please, in that case, could I have a firmware as described with 2 additional stepgens routed via the 7i52, and the remaining inputs configured for encoders?
Many thanks!
2 years 11 months ago #286267 by PCW
Here is firmware for a 5I23 + 7I48 + 7I52
with 2 stepgens and 1 PWMgen (PWM only no dir) on the 7I52
(and only one sserial port)
The spare inputs add 2 more encoders (so total of 14 encoders)
2 encoders are aliased so 16 show up but only 14 are usable
File Name: 5i23_fmd.zip
File Size:77.7 KB
2 years 11 months ago #286275 by freemoore
Thank you! I'm out of the workshop for the evening but that looks good, I'll try it out tomorrow. I should be able to use that PWM with the CW and CCW relays via the 7i84. Thanks again.
Andy
2 years 11 months ago #286277 by freemoore
A couple more questions for thiis evening: which PWMgen setting will be needed for the 7i52 pwm? IIRC my main card, the 7i48, needed pwmgen type to be set to 2 - up/down mode.
Also, if I have 1 pwmgen pin, am I right in thinking that I have two ways to get bidirectional spindle control:
1 - set 50% duty cycle to mean 0rpm, less to mean CCW rotation and more to mean CW rotation with full speeds at 0% and 100% respectively, or
2 - use 0% to 100% and use a pin from 7i84 to set spindle direction?
thanks,
Andy
2 years 11 months ago #286292 by PCW
If your spindle control can set 0 speed as 1/2 way up PWM
than that should work but note that you will get full speed
when LinuxCNC is not running (since PWM would be off)
so you need a separate enable (perhaps from the 7I84).
This mode is supported in the hostmot2 driver for PWM as "offset mode"
2 years 11 months ago #286311 by freemoore
On changing my ini file to try out this new firmware I get this error:
IDROM IOPorts is 3 but MD IOPort NumInstances is 6, inconsistent firmware, aborting driver load
I've created and attached the report file.
Moderators: PCW, jmelson
Time to create page: 0.309 seconds
