7I33TA Just plug it in?
2 years 1 week ago #312614 by PCW
Replied by PCW on topic 7I33TA Just plug it in?
Did you try step_type 2?
This is quadrature mode and has square wave output.
(if the stepgen scale  is set to 1, the output frequence is directly
settable in Hz)
Also with OPTOs you need to limit the input LED current
to the minimum required to get the quickest turn off,
maximum frequency.
2 years 1 week ago #312626 by Deckerjwd
Replied by Deckerjwd on topic 7I33TA Just plug it in?
so i need a resistor, it is an amazon cheapo that i had around. i have some Darlington and transistors around here to. may pull the opto off the board and have a look
2 years 1 week ago #312633 by Deckerjwd
ok how do i write a driver for 5i24-25 with 7i52s, 7i33ta, 7i44.
i kinda want to know how that works. its an fpga right
2 years 1 week ago #312636 by PCW
You need 5I24-25 firmware for a 7I52S_7I33+7I44:
File Name: 5i24_25_7i...7i44.zip
File Size:165.91 KB
The following user(s) said Thank You: Deckerjwd
2 years 5 days ago #313326 by Deckerjwd
Ok firemware loaded np, but cant get any analog out
linuxcnc.org/docs/html/examples/spindle.html , I Follow section 1. "0-10 Volt Spindle Speed" or section 2. "PWM Spindle Speed"
the second on seem more likely for the 7i33ta
2 years 5 days ago #313332 by Deckerjwd
ok so just ran the mesa wizard and copied and pasted, some spindle stuff. works, need it to be always positive but ya works
Moderators: PCW, jmelson
Time to create page: 0.248 seconds
