7i95t firmware brick because i flashed a 7i95 bitfile in the fallback
8 months 3 weeks ago - 8 months 3 weeks ago #342489 by PCW
Did you have card access before at 192.168.1.121?
What does
ip a
report?
Also with W5,W6 = UP,UP, the fact that the /INIT led blinks means that
the fallback configuration in the flash EEPROM is valid and still works...
Last edit: 8 months 3 weeks ago by PCW.
8 months 3 weeks ago #342494 by Salrodri
I guess I never tried access to 192.168.1.121?
I have always used 10.10.10.11
Jumpers UP,UP
ip a reports
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether d8:9e:f3:91:96:8a brd ff:ff:ff:ff:ff:ff
altname enxd89ef391968a
Jumpers DN,DN
ip a reports
2: enp1s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
8 months 3 weeks ago #342495 by PCW
If UP.UP works, stay with that
Then setup you hosts Ethernet interface to a static IP address of say 192.168.1.100
(the current settings will not allow access to the card)
8 months 3 weeks ago #342496 by Salrodri
Beautiful!
You are hands down a genius
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=801 ttl=64 time=0.263 ms
64 bytes from 192.168.1.121: icmp_seq=802 ttl=64 time=0.109 ms
Do I still need to flash the fallback.bin and the .bin file?
if so, how can I point mesaflash to these files?
8 months 3 weeks ago #342503 by Salrodri
I remember you mention something about the dpll?
I was trying to create a machine to test the borad
Debug file information:
Note: Using POSIX realtime
./main.hal:37: parameter or pin 'hm2_7i95.0.dpll.01.timer-us' not found
22938
Stopping realtime threads
Unloading hal components
8 months 3 weeks ago #342504 by PCW
You need to install a user configuration (the fallback configuration has no modules except GPIO):
mesaflash --device 7i95t --addr 192.168.1.121 --write  7i95t_d.bin
(7i95t_d.bin  is from the 7i95t.zip file in configs/hostmot2)
Once this is done, you can set the IP select jumpers to DOWN,DOWN (192.168.1.121)
or DOWN,UP (10.10.10.10)
Moderators: PCW, jmelson
Time to create page: 0.367 seconds
