- Thank you received: 994
rodw wrote: Funny, we were both struggling with this at the same time. On another thread, Peter said for a 70 Hz filter the gain was:
PCW wrote: Rod:
0.355849556024592
( 1-e^(-2*pi*70*.001) )
(assuming 1 KHz sampling)
In my case, I had correctly assumed e = 2.718 but was let down by a crappy calculator on my Chromebook. Once I moved to Google Sheets, it was perfect! Thanks for the tip on spreadsheets John!
It would be good if the docs were updated to state:
where:
e = the mathematical constant 2.71828
and the more normal ^ symbol was used for yn instead of ** (which I've never seen in use)
rodw wrote: but unless you know what e is or what exp does, a user still can't replicate the formula. It still needs more detail in the docs.
