Login Form
Offset after Homing in Y-Axis
11 years 3 weeks ago - 11 years 3 weeks ago #63619 by LearningLinuxCNC
Todd is telling you exactly what to do.
Set HOME_OFFSET = 596mm
This means that when the machine hits the home switch it will set that position to 596mm.
Set HOME = 596mm
This means that after the machine homes it will move to the "HOME" position which is the same position as the home switch as defined by HOME_OFFSET. Since home and home offset are the same then the machine will not move after it homes.
Last edit: 11 years 3 weeks ago by LearningLinuxCNC.
Time to create page: 0.149 seconds
