Threading problem
- brianbonedoc
- Topic Author
10 years 11 months ago #65342
by brianbonedoc
Replied by brianbonedoc on topic Threading problem
Joe - yes I think you are right about that. Still super excited I got this far!
I am like a blind squirrel looking for a nut. . .
- verticalperformance
- Thank you received: 11
10 years 11 months ago #65562
by verticalperformance
Replied by verticalperformance on topic Threading problem
If you are using Linux CNC 2.7.0 and get crappy looking exit moves at the end of the thread when using an exit taper (E>0 in the G76) - put an F0 prior to the G76. This will give a nice clean threads at the exit that progressively reduce in depth. If exiting into a relief groove using E0, you won't see this problem.
Looking at your video there definitely seems a pause at the end of the thread prior to the exit - but that could be you are just using E0 too with no relief groove.
Bug found in new trajectory planner which looks like it will be resolved soon. forum.linuxcnc.org/forum/20-g-code/29685...aper-linux-cnc-2-7-0 . 2.6.x does not have this issue.
Looks like you have been having similar fun to me by converting a machine that was not really designed to do this. Mine even less so being a Sherline! But haven't had to put the change gears on since!
Have fun!
Have fun!
10 years 11 months ago #65565
Replied by andypugh on topic Threading problem
I normally don't use exit taper or relief groove. With CNC you can run threads right up to a shoulder and retract reliably in a fraction of a spindle revolution.
You may need a relief groove in some cases to allow the mating part to pull up tight, of course.
- brianbonedoc
- Topic Author
10 years 11 months ago #65578
by brianbonedoc
I'm using tormachs pathpilot version which is based on 2.6 so I haven't see any weirdness that I didn't cause myself
- brianbonedoc
- Topic Author
10 years 11 months ago #65660
by brianbonedoc
Now that I have everything up and running here are my final ini/hal files - for anyone who needs them.
10 years 10 months ago - 10 years 10 months ago #66353
by Iron-Man
Brianbonedoc when gcode is running in pathpilot lathe, does the rpm show in the RPM window? If yes then I have one more function to connect.
Thanks,
Iron-Man
Replied by Iron-Man on topic Threading problem
brianbonedoc wrote: I'm using tormachs pathpilot version which is based on 2.6 so I haven't see any weirdness that I didn't cause myself
Thanks,
Iron-Man
Last edit: 10 years 10 months ago by Iron-Man.
Time to create page: 0.060 seconds
