Micromet wrote: It seems the only stand-alone linuxcnc simulator package is for Ubuntu distros..
Micromet wrote: bit of an inconvenience having to go and turn on the workshop machine and then back to the office.
.SVG files are human-readable, so have a look in there.
:How can I improve the quality of the output of Potrace?
The most effective way to do so is to improve the quality of the input! This seems obvious, but not everybody thinks of this. Scan your image at a higher resolution. Scan your image in greyscale, and use a program such as mkbitmap to generate a high-resolution bitmap to trace.
In some cases, it also helps to decrease the resolution of the input image. If the resolution of your input file is incredibly high, the output generated by Potrace might be larger than necessary. This also sometimes happens if the input is speckly or noisy. Rather than trying to simplify the vector image, it often helps to just downscale the input bitmap.
How can I reduce the number of nodes in the output of Potrace?
For many applications, the problem of reducing output file size can be solved by reducing the resolution of the input image. This sounds too simple to be true, but can give surprisingly good results. One of the most common "beginner's mistakes" when using Potrace is to start with an image that contains too much detail or noise. Blurring the input image can also help, particularly with grey-scale images.
