Run-from-line and v.2.7.3
10 years 8 months ago - 10 years 8 months ago #69733 by Paul
Replied by Paul on topic Run-from-line and v.2.7.3
OK - More testing done. What I am finding is that LinuxCNC now looks in the touchoff subroutine and performs only the G38.2 even though the call to the sub is earlier in the gcode file. If I replace the call to the sub with the contents of the sub, run-from-line works as I expect (it doesn't perform the G38.2). If I remove the G38.2 from the sub, nothing else in the sub seems to matter when running from line.
Sample test GCode fle:
G21 (Units: Metric) F1 S1 G00 X0.000 o<Test.TouchOff> call G00 Z3.8100 M03 S1 G01 Z3.8100 F3002 G04 P0.2 G01 Z1.5240 F3001.0 G01 X150.000 F4000.0 G01 X250.000 F2000.000 M05 G00 Z20.000 M05 M30
Touch-off routine:
o<test.touchoff> sub G38.2 Z-100 F3001.0 G10 L20 P1 Z0.000 G00 Z9.90000 G10 L20 P1 Z0.00 o<test.touchoff> endsub M2
If I run-from-line at "G01 X250.000 F2000.000", it will -Z until the probe switch is engaged and hold that Z position while moving X to 250.000.
I did remove preample and other info wanting to remove anything that may interfere with this test. Again - I haven't changed my setup, so I still wonder what has changed in v.2.7.3, but I can imagine that I can't understand the answer, too.
Thanks for any insight...
Last edit: 10 years 8 months ago by Paul.
10 years 8 months ago #69754 by mozmck
Replied by mozmck on topic Run-from-line and v.2.7.3
Yes, I have found that run-from-line does not work properly if you call subroutines (at least if there are also G38.2 moves as well). The only workaround I found was to not use subroutines.
What version of linuxcnc did this work on? Were you using subroutines there as well?
10 years 8 months ago - 10 years 8 months ago #69757 by Paul
I am not 100% sure of the version previously, but believe it was 2.7.0. I don't update it very often and think it was September. And, yes, I used subroutines with the last version I had. I did not notice any issues then.
There may be more to it. After I placed the contents of my subroutine directly in the main file, I had another unusual reaction that I need to look at closer, but after I removed just the G38.2 from the main file, the run from line seem to raise the Z axis up suspiciously close to the touch-off switch offset of 9.9mm from the Z's current location even if Z was not at 0 or less than 0. The run-from-line did not raise the Z while the call the the sub was in place and the G38.2 probe only was removed from the sub routine.
Like I mentioned, I need to test that out more, too.
10 years 8 months ago #69804 by Paul
I did pull a backup in order to finish a job. It was v.2.7.0 which works fine. I never ran a version in between. I would rather not convert all current jobs to not use a subroutine.
10 years 8 months ago #69868 by andypugh
Replied by andypugh on topic Run-from-line and v.2.7.3
Does this sound anything like your situation?
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...ba9a44fe3f2836861262
This is meant to _fix_ a bug. Perhaps you were getting lucky with the bug working in your favour?
10 years 8 months ago #69875 by Paul
While I admit that I don't fully understand the bug description, I believe mine does not match. It looks like the posted bug will skip some lines AFTER the line which is selected for run-from-line. What I have here is only a G38.2 that is in an external file subroutine that is called before the run-from-line.
There are times I get by because I have flat, uncut material under the torch. The torch drags a little while moving to the next pierce. There are times that the torch goes for this un-intended probe in a void of material, so that resulting drag would hit the edge of material and move it out of place. Basically ruining the job.
I will re-read the bug description a few more times to see what sinks in. If it is the same thing, I respectfully request the bug to be unfixed :)
Time to create page: 0.340 seconds
