Python linuxcnc.stat() showing no result.
8 years 5 months ago #110765
Replied by andypugh on topic Python linuxcnc.stat() showing no result.
I think you need to run the rip-environment script in the second window prior to opening python.
Or use linuxcnc& in the first window to get back to the command line after launching linuxcnc (probably better)
The following user(s) said Thank You: kpj10
8 years 5 months ago #110767
by kpj10
Replied by kpj10 on topic Python linuxcnc.stat() showing no result.
I'll try out your second suggestion, because the first suggested solution is the approach i follow.
Time to create page: 0.044 seconds
