- Thank you received: 358
It looks like too much work. Unfortunately I don't have time nor much of a desire to do all thatAnother way you could use a pin for more than one purpose is to set a pin using M62-M65 in gcode and connect that output pin to a MUX2 to swap pin signals on that command. You might be able to use this when probing for instance.
It would be interesting to see you could use the plasmac config with your THC. So far most people have been using a mesa THCAD board but it has a mode to support your style of THC. Whilst this requires a recompile to include the reverse run branch that is not yet in Linuxcnc master branch, you could run your existing mill subject to the usual changes required to move from V 2.7 to V 2.8 for independent axes and multi spindle support.
I'm developing a custom THC so it may or may not need anythingMost plasmas will need the arcok true for the entire cut or they will think the torch has gone out.
Sounds good. Could you please elaborate on how can I hook it up in my hal file?How about 2 pins:
1 = Up
2 = Down
1 + 2 = Arc OK
No pins = something bad happened.
1 = Up
2 = Down
1 + 2 = Arc OK
